Carb issues
Old Jul 6, 2004 | 05:50 PM
lovintha7's Avatar
Suicidal Death Missile
Carb issues
Well, I took the air horn off my Nikki today, and adjusted and cleaned the float valves, and the floats. I fired it up, let it run for a few minutes (it was still warm) and shut it off. I fixed the stuttering at idle, and surging, but for some reason, if I wait about 2 minutes, gas begins to build up on the secondary throttle plates. So I restarted, and ran it again. I looked real close after I shut it off, and gas appears to be coming out of the throttle shaft!Nothing seemed to be running out of the secondary venturies. I did notice that the venturies do move a little bit back and forth, is that normal? Are my throttle shafts worn?
Please help, this flooding **** while shut off is getting very aggrivating to start at WOT.....
Old Jul 6, 2004 | 06:12 PM
FB II's Avatar
tap the banjo fittings and check your fuel pressure. also make sure your secondary float level is good. not too much.
Old Jul 6, 2004 | 08:54 PM
lovintha7's Avatar
Float levels are good, and the banjo bolts are tight. I don't get it.....You take the payment plan on carbs Sterling?
Old Jul 6, 2004 | 09:15 PM
Anex 570's Avatar
It Runs!
Just stick with it and keep tapping it. I came to believe its a rebuild blues type thing. They say when you mess with the needles they need to seat again or something, I let mine sit over night and it worked fine, I had the EXACT problem. I also made sure like 10 times the vent solenoid was working. You'll hear a pretty decent loud CLICK or CLACK . Just keep tapping and trial and error, they're real simple in stock form.
Old Jul 6, 2004 | 09:17 PM
lovintha7's Avatar
I'm about to break out the BFH.......
Old Jul 7, 2004 | 12:11 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
I try to be as flexible as I can.
Like Anex says, if that solenoid isn't hooked up...
Old Jul 7, 2004 | 06:29 AM
lovintha7's Avatar
The vent solonoid is the solonoid on the driver's side of the carb, underneath the fuel lines.
Old Jul 7, 2004 | 10:50 AM
Rx7carl's Avatar
Airflow is my life
Yes.
Look into the secs while running to see where the fuel is comming from.
rgordon1979
40
Mar 15, 2022 12:04 PM
Clacor
Sep 11, 2015 08:36 PM
<<Ayrton>>
Interior / Exterior / Audio
Sep 5, 2015 09:38 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
