14" wheels or 16"
Old Nov 14, 2001 | 10:16 PM
4rxz's Avatar
14" wheels or 16"
quick ???
4 log on 14" wheel 195/50/r14
would spin faster but push/grip the car slower
but burn tire on take off
5 log on 16" wheel 255/50/r16
would spin slower but imetiately force the car to take off and accelerate faster holding the weight
better
but of course burning cloud smoke at takeoff look a lot faster if your watching from outside
what to you guys think???
Old Nov 14, 2001 | 10:48 PM
Dak's Avatar
Dak
Information Regurgitator
You've got me confused with the 4 lug,5 lug thing because the number of lug nuts has no bearing on grip and you can't put 5 lug wheels on a 4lug car without doing the 4 to 5 lug conversion,but I'll take a shot at your question anyway.The 255/50/16 would have more grip because it is wider so with a good launch I think so it should be alittle quiker.16s look better so I'd use them only problem is I don't think(but am not sure)you can run a255 with the stock offset on the rear and I don't thin a 255 will fit on the front at all.So be careful to get the right offset when you buy rims.
Old Nov 14, 2001 | 11:29 PM
4rxz's Avatar
opps
245 on back 225 on front
i ask since i have a gtu-s diff 4.33 gear ra
i did the 5 log conv. but i notice 4 log smaller rim made a lot of smoke but did move the car much
Old Nov 15, 2001 | 12:17 AM
Dak's Avatar
Dak
Ok I'm not confused anymore.Wider tires should give better grip and the lower sidewall should help it corner as there is less flexing of the sidewall.
Old Nov 15, 2001 | 01:57 AM
well i got 17" on mine they are 215/40/17 wider foot print but i tend to bounce around curves instead of hugging the curve i take that is from the lower profile ther is no car body roll so the centrificual force is pushing me through the turns....
Old Nov 15, 2001 | 03:55 PM
4rxz's Avatar
thanks
FB_Frank85
Sep 6, 2015 11:29 AM
