function of rad. temp sensor?
Old Nov 14, 2001 | 05:50 PM
i'm putting in a griffin rad.,just need to know,if somebody can tell me,what the sensor is for in the bottom of the radiator,so i can figuere out if it can be eliminated or not.thanks.
d
Old Nov 14, 2001 | 07:00 PM
HAILERS's Avatar
HAILERS
It WILL keep the car from doing the standard 17 second fasts idle when started (approx 3000rpm) and it will make the relief solenoid (the blue one) work improperly keeping the relief valve in the air control valve open when it normally not be open (emissions). The above is true if you do not have it functioning.
Old Nov 15, 2001 | 12:36 AM
so,then,since i dont have any emmisions on my car,the only thing would be the lack of high idle at startup....correct?this sounds like a good thing....!thanks
troym55
23
May 25, 2016 12:42 PM
The1Sun
Sep 15, 2015 04:45 PM
msilvia
15
Sep 11, 2015 12:13 PM
