Back Windows
Old Jul 2, 2004 | 04:17 PM
BIG J MIXALOT's Avatar
SHSHSHA POCKET SAND
Back Windows
how do you pull out the back windows the side ones
Old Jul 2, 2004 | 04:54 PM
SHSHSHA POCKET SAND
anyone
Old Jul 2, 2004 | 06:00 PM
rhinor61's Avatar
There is 1 10mm head nut on the inside, retainer clip at the point on the outside held on by a phillips head screw.
And some very strong thin wire and cut the glue between the glass and body.
I break 85% of the ones I try to take out.
John
Old Jul 2, 2004 | 06:14 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Yea pull the nut and the take off the clip, Use a razor knife to cut a spot to put the wire, Last one I did, I took the Hot start assist cable appart, niped the ends and used vice grips on each end. Get some on the inside and saw back and forth. When you get to where the nut was there is a stud there. Find a way to go around it.
Old Jul 2, 2004 | 10:06 PM
jimmyjoejoe's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
badger badger badger badger
Old Jul 2, 2004 | 10:10 PM
mushroom mushroom
Old Jul 3, 2004 | 04:14 AM
SERIES 1 XLR8's Avatar
SNAKE SNAKE....................www.badgerbadgerbadger.com
lol
Old Jul 3, 2004 | 11:38 AM
perfect_circle's Avatar
oooh its a snake
Th0m4s
Feb 26, 2019 02:04 AM
bURGRotary87
Aug 19, 2015 03:54 AM
cam_7779
Aug 18, 2015 07:48 AM
