Good Alignment Shop in SoCal
Old Nov 14, 2001 | 10:23 AM
carcrazy's Avatar
I am looking for a good alignment shop in Southern California near Irvine to take my RX-7 to. Need to alignment both front and back as it is fairly messed up.
take care
Rick
1993 RX-7
Old Nov 14, 2001 | 04:19 PM
A-Spec's Avatar
you can drive 2 hours to Santa Barbara, there's a really nice one in town. Everything is computerized and it uses lazers, well maybe not lazers but they put light sensors on each tire and the main machine shines at it with LED's... Gives you a print out of all your camber, caster, toe-in etc etc. also. Not the semi-ghetto ones at discount tires. think it was $90..and $40 for gas to drive here
David
Old Nov 14, 2001 | 04:26 PM
maxpesce's Avatar
Ex fd *****
David:
please shoot me the name of that shop in SB - I need an alignment after messing mine up at Willow Springs on Friday!
I work at El Mercardo Plaza on upper State St
Old Nov 14, 2001 | 05:29 PM
A-Spec's Avatar
wow you drive that far everyday to work!??!?! I live off La Cumbre
the shop is in Goleta, it is called superior brake and alignment. The number is 964-1167. It should be Don working the phones. Really cool and really good driver
David
Old Nov 14, 2001 | 05:31 PM
A-Spec's Avatar
hey are you going to the SpeedTrialUSA event on the 24th?? it is going to be my first time hope I don't fudge up....
David
Old Nov 14, 2001 | 09:56 PM
carcrazy's Avatar
Originally posted by maxpesce
David:
How did you do at Willow? A friend of mine named Doug in a silver C5 Corvette was out there also. He was supposedly quite fast.
take care!
Rick
1993 RX-7
Old Nov 14, 2001 | 09:59 PM
carcrazy's Avatar
I could also possibly visit one in San Diego also...
If someone recommends one in San Diego, I will just drive the RX-7 to SD for work.
regards
Rick
1993 RX-7
Old Nov 15, 2001 | 11:08 AM
maxpesce's Avatar
Ex fd *****
take care!
Rick
1993 RX-7
It was my first time on a real track - there were a couple of C5's and a Z06, was he the heavily modified one with all the decals?
Ask Your friend if he caught my Big Spin (driving my Silver 3rd gen)on the main straight!
Old Nov 15, 2001 | 11:10 AM
maxpesce's Avatar
Ex fd *****
David
No - I dont think I will be able to do another Track event for a while - I need to get some New Tires before i head out to the track again.
Old Nov 15, 2001 | 11:17 PM
carcrazy's Avatar
I will ask him about the spin. He was the silver C5 with no decals and just an exhaust and intake system mod. Supposedly, he was the fastest in his group.
Rick
1993 RX-7
Old Nov 15, 2001 | 11:19 PM
carcrazy's Avatar
After visiting several shops around in the area, they could not either take the car on their ramps (too low) or could not fit the adapter on the wheels as they are 18". I will take the car to Goodyear in the next couple of days and let you know the results. They are charging lots of dough though. Something like $125 for the alignment.
regards
Rick
1993 RX-7
Old Nov 16, 2001 | 02:27 AM
spigot's Avatar
From my experiance trying to get a good suspension setup in Orange county, there is no one willing/able to do the things I want.
I have gab super R's with the coil over conversion, 18" rims and I'm really **** about the suspension.
There were only a few places that had the scales to do corner ballancing, most were porsche places and they wouldn't even consider it since they were all soooo busy. Xpengineering (www.xpengineering.com) is in orange and apparently has scales, but I'm reasonably sure they don't have an alignment rack, maby laser strings. I'm going to try them next time I need mine done when the busing set gets put in.)
I ended up driving upto Canoga park to have tripoint do it. They did do a really good job, even though it was expensive.
I'd be interested to hear where som of the other OC people go (Max Cooper)
Matt
Old Nov 16, 2001 | 01:35 PM
carcrazy's Avatar
Got the car aligned at the local Goodyear place for $125. It took them about 1 hr to do it - no parts required.
They found the rear was toed out a bit as well as one of the tires in the front. The car tracks better and feels more planted. However, when your foot dips into the power, the car gets all 'skwormy' again. It is not bad - just subtle and annoying. It is just enough to break your confidence. I did get it up to 130 mph in a short little distance and was not too bad. It is just when power is being applied.
In thinking about all the dynamics the car is doing and my "finely tuned *** muscles" it seems like the springing is far too soft for this car. The car squats way too much as it loses wheel travel. Any bumps the car encounters causes the car to dart and become unstable. I am maybe encountering some bump steer as well. The car also rides l o w.
Therefore, I will now look at replacing the springs. Any spring recommendations for a 400-425 hp RX-7 with 18" wheels? Not interested in coil-overs at this point as the wife would not want to spend the big dollars right now - Christmas and all.
Any help/recommendations would be great!
Rick
1993 RX-7
(almost dialed in!)
Old Nov 16, 2001 | 06:21 PM
carcrazy's Avatar
Rick
1993 RX-7
He did see it! He said you came off the track on the left side because your wheel hit the right berm at turn one. This action upset your car as you spun off in the dirt. He said you should of done the trick with both feet in (one foot on the clutch and one on the brake). This would of been safer for you and the track.
Oh well, you live and learn. Remember, it is the turns that count!!!
Master them and the straights are a piece of cake. Just advice!
Rick
1993 RX-7
auggie463
21
Sep 2, 2015 01:46 PM
rx7jocke
Aug 15, 2015 03:36 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
