Sponsored by: CARiD
Loss Of Power, Sputtering Noise, Clogged Cats???? Help!!!!!!
Old Jul 1, 2004 | 08:37 PM
L337rx7's Avatar
I own an 88' RX-7 GTU. I've recently noticed a slight sputtering noise, not the normal back pressure pops after revving the engine, but a more consistant putputputputput. I've also noticed a loss of power, and when it is hot out from idle to about 4000 rpm there is a "woooshing" noise, i belive eminating from the fan, fanbelt. IF anyone has any ideas, please help.
Old Jul 9, 2004 | 01:49 PM
Cosmo Donk's Avatar
Queer
Why get rid of the fan belt? The mech fan is just fine. Pull the cats and check them and then, if the neighbors don't mind, run the car with no cats to see if it has problems. Although if it is clogged or chunked enough you will not even have to bother running the car.
Queppa
Nov 18, 2024 03:47 AM
msilvia
28
Apr 14, 2016 12:58 PM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
PhillyFC
Aug 21, 2015 06:36 PM
