Microtech Error Check - I have a few questions
Old Jul 1, 2004 | 05:05 PM
silverrotor's Avatar
Arrow Error Check - I have a few questions
I decided to smooth out my Idle Maps today. With good success I shut my car off to cool down. A short while later I started It up again to find out I had Errors on both Error Check screen 1 & 2.
Under screen 1 ~ Error - Ref
Under screen 2 ~ Error - RPM
I do believe this was talked about before (I'm not sure to what extent). I've searched but couldn't find what I was looking for. What are these Errors? What may have caused them and how do you corect these?
Old Jul 1, 2004 | 06:07 PM
SwooshMan's Avatar
I used to get rpm errors every so often, but only when the car had died from the electrical load. since i've richened up my idle map i havent seen it again. I got the REF error once too but i have no idea what from. Sorry, i'd like to know as well.
Old Jul 1, 2004 | 08:23 PM
Okay, It gets stranger now...
B'c I was abit mistified on these errors, I went out again to see If I missed or overlooked something...well I'll be damned! It was gone.
Is there an explanation for this? What Is Error - Ref & RPM mean?
Old Jul 2, 2004 | 09:04 AM
Josepi's Avatar
Despise Enmity
RPM error is a botched signal from the CAS, typically caused by the wiring for the signal pickup picking up (pun!) eletrical interference.
Ref...dunno right now, it's still early in the AM
Old Jul 4, 2004 | 06:26 AM
Infini IV's Avatar
Microtech Tuning!
Try to route your CAS shielded wire away from the alternator wires and pretty much every other wire.
Old Jul 11, 2004 | 08:36 PM
A clear definition on these would be an asset.
smikels
Rtek Forum
May 12, 2016 12:34 AM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
elfking
Aug 19, 2015 09:48 PM
