Haltech Overheating Inj? Stuttering prob
Old Jun 29, 2004 | 10:15 AM
RevinRx7's Avatar
Concerned Citizen
Hey I'm having a little trouble right now. When My car is reaching operating temp after i'd say about 10 minutes, the car starts to break up. Now I thought before this was because I was heating up the coolant so hot it was boiling. I flushed the **** browness out of my engine and filled it w/ a cleaner then flusher again and filled w/ some new stuff.
Now that I checked the ecu's telling me I'm only see 187 degrees 190 at the highest.
It then starts to break up again. Once it breaks up, it dies and won't hot start.
Also my injectors are hotter than I think they should ever be. I'm trying to do a street tune now. So i don't think I would be maxxing the injector.
Also this is just revving at a stand still no driving yet.
Any Ideas i'm kinda stumped
Old Oct 3, 2004 | 02:33 PM
danec020's Avatar
I have a similar problem to this, did you ever fix yours?
Old Oct 3, 2004 | 09:44 PM
RETed's Avatar
Did it run okay before???
-Ted
Old Oct 5, 2004 | 11:18 AM
RevinRx7's Avatar
Concerned Citizen
No i never got around to fixxing it, I had to go to school.
Before what?
Old Oct 5, 2004 | 11:22 PM
RETed's Avatar
The maps might need more tuning.
-Ted
Old Oct 6, 2004 | 12:43 PM
RevinRx7's Avatar
Concerned Citizen
Random question, I've been listening to my exhaust, and i can hear each pulse distinctly, but it keeps sounding like there is a metal chattering noise on top of this, what do yu think that would be, bad timing? I checked and it was dead nuts on tho
Old Oct 6, 2004 | 12:48 PM
RETed's Avatar
Ignition timing does not change much with changing coolant temp unless you have a modified Ignition Coolant Map?
I think most of the default base maps floating around have them flat?
It sounds like your fuel maps and Coolant maps needs tuning.
-Ted
Old Oct 7, 2004 | 03:00 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
are any of your sensors going into fault????
My car did that and it turned out to be a bad connection on the coolant sensor, car would run like **** and die when it got warmed up and wouldn't run right again till it got cooled down. Turned out that the connector for the water temp sensor was bad and when it got hot, it would split apart and the ECU would start dumping fuel in like a madman..
check the engine data page to see if one of your sensors is faulting out after the car gets hot.
What's the A/F when it starts to break up???? (you'd better get ahold of a wideband if you don't have one already)
Are you running the stock fuel rails?????
Old Oct 7, 2004 | 03:42 PM
RevinRx7's Avatar
Concerned Citizen
Ok I'll have to check that out. I have just a normal O2 sensor in right now to give me an Idea. Yes I am running the stock fuel rail. I'm running just about stock everything right now. I have no intercooler pipes either so.....its not seeing any boost. Still working on completing everything
Old Oct 11, 2004 | 08:00 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
The only other time ive hear a rotary engine NOT sound like a rotary is when the water jacket on the motor went south on us. It was putting water in the compression chamber and spitting out the exhaust, it sounded like a strange motorcycle engine and the motor was hard to start.
And since you mentioned the fact that you had to flush your engine from to much crud in it id thing thats a possibility.
Old Oct 11, 2004 | 11:09 AM
RevinRx7's Avatar
Concerned Citizen
That could be a possibility, but I think the reason it needed a flush was to get all the old coolant out. Since it is a used RE motor. But I'll pressure test the coolant system and do a compression check. Thanks for the advice
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
Microtech
Sep 27, 2015 09:28 AM
Devon Murray
Sep 25, 2015 09:41 AM
RX200013B
Haltech Forum
Sep 23, 2015 08:47 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
