Apexi Intake Question!!!!!
Old Nov 13, 2001 | 06:52 PM
Exclamation Apexi Intake Question!!!!!
Hey all,
I need some help... I just installed an apexi intake system and I’m get a weird sound from one of the air cleaners, if anyone has any advice or the same system please respond ... Thanks
Old Nov 13, 2001 | 09:29 PM
Mahjik's Avatar
Mr. Links
Usually when you add an open intake, you'll hear your engine a lot more as you go higher in the RPM's.
I'm guessing that's what you are hearing.
Old Nov 13, 2001 | 09:34 PM
spooledUP7's Avatar
There and back again
It's actually the air pump that makes that sound. You will notice it mostly below 3000RPM when the Airpump is kicked on. I kind of like it. Sounds a little growly. I still have the stock exhaust, so I get t pretend that I have a little monster under the hood when I get a load on the air pump. I imagen that people with a high flow exhaust don't really hear it over the exhaust sound.
Old Nov 14, 2001 | 09:16 AM
thanks for the replies...
spooled7- that's exactly what I'm hearing...
Thanks again
Snoopy FD
Dec 8, 2015 01:45 PM
