Power FC O2 sensor?
Old Nov 13, 2001 | 08:56 AM
Dimcorner's Avatar
Man Whore
O2 sensor?
Ok, can the PFC measure the voltage of the O2 sensor and more importantly WHERE DO I SEE THIS?
Also...
Instead of someone saying "look in this link" can someone be more specific on which map would I need for the following setup...
Big street port
Flywheel
Pettit Intake
DP
MP
Catback
Power Pulley
Supra Fuel pump
Stock IC
Stock Injectors.
Thanks
Old Nov 13, 2001 | 11:08 AM
cewrx7r1's Avatar
Eye In The Sky
Page 35 of the manual which can be seen under this forum.
Old Nov 13, 2001 | 11:18 AM
Dimcorner's Avatar
Man Whore
BAD ***!!!!!!! THANKS A ZILLION!!!
now what's normal reading...?
Old Nov 13, 2001 | 12:43 PM
cewrx7r1's Avatar
Eye In The Sky
Normal?? Mine reads from .01 to .05 at idle warmed up and depending on engine load. Under closed loop driving; from .1s to .7 depending on speed, 0 to 80mph. Under boost, .85 to .9.
Old Nov 18, 2001 | 05:25 AM
rotaryextreme's Avatar
Veteran: Navy
o2 reading
The o2 reading on the power fc does not mean anything. The o2 reading also depends on the exhaust temperature. In fact, the positon of our o2 sensor is too close to the exhaust source. It should be farther down the pipe. Right now I have a T51R kai turbo and I also use the Greddy A/F gauge. I put the Greddy oxygen sensor at the original oxygen sensor bun on the HKS downipe. The Greddy a/f meter has a over heating warning feature. If the exhaust temperature is more than 800 C, the warning light will be flashing. When the sensor overheats, the reading is not accurate. Mine over heats the whole time even though just cruising on the freeway. If you really want to use that, I would suggest you to put the oxygen sensor farther down toward the end of your downpipe. My power fc reading at full thrttle is 1.2 V. I put my car on the dyno and use the wide band lambda sensor, the a/f ratio is 11-11.5. Now can you depend on the power fc reading?
Chuck
Old Dec 29, 2002 | 01:13 PM
SleepR1's Avatar
Question lambda O2 Sensor
Is this just a drop-in replacement for the stock O2 sensor? Will using a lambda sensor help the Apex Power FC and tuning to the proper AFRs?
Where do I buy a lambdo O2 sensor, and how much?
Old Dec 29, 2002 | 01:58 PM
Badog's Avatar
Re: lambda O2 Sensor
Manny,
A WB O2 sensor (aka Lambda) is not going to do you any good unless you have the heater and circuits to run it. That is where the TechEdge and FJO Wideband kits come in. They package the required hardware to provide the AFR readings.
I suggest highly that a new bung be added for tuning, and it is positioned not greater than 3-4' of the output of the (last) turbo.
Tony
Old Dec 29, 2002 | 02:50 PM
SleepR1's Avatar
Re: Re: lambda O2 Sensor
What is the FJO wide band kit?
I'm a newbie to all this stuff, can you tell ?
Originally posted by Badog
Manny,
Tony
Old Dec 29, 2002 | 02:56 PM
Badog's Avatar
Hey Manny,
Do a search! Lol!
FJO and Techedge are two companies offering fairly inexpensive wideband O2 monitoring kits.
http://www.fjoinc.com/
http://www.techedge.com.au/vehicle/wbo2/default.htm
Old Dec 29, 2002 | 02:58 PM
SleepR1's Avatar
Walker Oxygen Sensor
Chuck Westbrook posted this link for $36 direct replacement oxygen sensor. I was just wanting to replace the old O-2 sensor with a brand new one, so the Apex Power FC is getting decent AFR data??
http://www.oxygensensors.com/
Old Dec 29, 2002 | 03:06 PM
SleepR1's Avatar
None of these wideband oxygen sensore will hook up to the stock engine harness, and so the Power FC won't be able to do read the data from the lambda sensor?
Hey Manny,
Do a search! Lol!
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
