Oil in tank for single turbo .
Old Jun 23, 2004 | 06:36 PM
sevenin7's Avatar
I would like to know if its necessary to put some oil in tank for single turbo fd and who can inform me about the correct proportion ?
Thanks in advance !
Old Jun 23, 2004 | 09:06 PM
danielsan's Avatar
Newbie
By tank I'm assuming you mean fuel tank: NO, you only need oil in your tank if your oil metering pump is no longer functional (ie. you've installed a Haltech).
If you ARE no longer running the OMP, get a good 2 stroke oil and mix about 150:1. I run Swepco 2 stroke oil at about 150:1, this is roughly what the OMP meters the oil at full throttle (if I remember correctly).
Old Jun 24, 2004 | 07:17 AM
sevenin7's Avatar
Yes ,in fuel tank .
i'm running single , with motec m4 ecu .
Please explain me what do you mean ...150:1.
If i make a full fuel tank (76lit ) how much oil its necessary to mix together ?
Old Jun 24, 2004 | 10:06 PM
CrazyCanuck's Avatar
I'm not familiar with the Motec, not sure if it runs your oil metering pump. If it doesn't, 150:1 means 150 parts fuel for 1 part oil (ie. 76 liters of gas, @500 ml of oil).
Old Jun 25, 2004 | 12:44 AM
IRPerformance's Avatar
Sponsor
I'm a firm believer that all rotaries should run premix, especially if you have 3mm seals.
Old Jun 26, 2004 | 01:58 PM
sevenin7's Avatar
Thanks guys !
sherff
Feb 24, 2019 12:09 PM
