Propane questions
Old Jun 22, 2004 | 12:32 AM
Conundrum 4000's Avatar
Propane questions
have any of you ever tried propane ? it has a higher octane level around 105 just wonder i am going to be building up a rx7 engine for my gt40 kit car i plan on running sumthing like a t72 at around 30psi, thinking of running propane and just switching over to carbs instead of fuel injection, also i will be getting new apex seals just wondering what would be good, i hear ceramic is great if so 1 peice or multi peice, thanks mike
Old Jun 22, 2004 | 02:11 AM
DrunkenBowler's Avatar
The only thing i've heard about propane is that it is used in diesel motors. It supposed to act like nitrous oxide on a regular motor. Anyways, good luck to ya. Try it out if your not sure and tell us the results. I'd like to know if it works.
Old Jun 22, 2004 | 09:12 AM
93rotorhead's Avatar
I was thinking of this same propane setup for my car. www.onlygoodstuff.com has a nice kit but it is used mostly on grandnationals.. I have decided to run water injection instead just because alot more rotary guys use water but good luck with the propane.
Old Jun 22, 2004 | 10:50 AM
well i don't plan to run it like you would run water injection, i plan to run strictly on propane, my dad has all of his stock gas powered trucks running propane, it makes a little bit less power, but with the higher octane i can run more bosst , and plus propane is alot cheaper too
Old Jun 23, 2004 | 09:54 PM
Sl0w7's Avatar
you are thinking backwards... people use it in wet nitrous kits... BUT it is a sorce of fuel NOT oxygen...
-Keith
Old Jun 25, 2004 | 08:06 AM
surfpac's Avatar
Yes, propane is a lot cheaper than gas. I believe propane is going for around $1.80/gal now. i've been thinking about propane for some time now and have some links for you. Also, there is a guy Down Under who built a 1st Gen to run strictly on propane and is pushing around 360 Hp.
http://www.truckworld.com/4x4-OffRoa...rboWillys.html
http://www.caranddriver.com/article....rticle_id=2279
http://www.wps.com/LPG/LPG-carb-theory.html
http://www.impco.ws/products.htm
http://www.alternatefuelsracing.com/
http://www.wps.com/LPG/index.html#INDEX
http://www.zonk.com/hotrod.htm
Old Jun 25, 2004 | 08:08 AM
surfpac's Avatar
Correct! and more timing as well.
Old Jun 25, 2004 | 09:47 AM
Skip at KDR I think said he had a rotary powerd truck that run off propane. Call him
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
