TD-06 upgrade
Old Jun 19, 2004 | 11:18 AM
gohorns's Avatar
Question TD-06 upgrade
hello rotorheads
i have a the old greddy TD-06 setup and want to upgrade to slightly bigger turbo with more punch. Are there any turbos i can upgrade to using the current manifold? or will the current manifold be choking it?
looking for similar spool up and low end power
suggesions?
Old Jun 23, 2004 | 08:14 AM
inukai's Avatar
Give me more info
There are several TD06.
TD06-20G-8cm
TD06-20G-12cm
TD06-20G-16cm
TD06-20G-20cm
TD06-25G-8cm
TD06-25G-12cm
TD06-25G-16cm
TD06-25G-20cm
TD06SH-12cm
TD06SH-16cm
TD06SH-20cm
Old Jun 24, 2004 | 08:11 PM
widebody2's Avatar
addicted to lounge
What footprint does it use? T4?
Old Jun 25, 2004 | 06:51 AM
jantore's Avatar
I have just installed the TD06H-25G-20cm
and im hoping for about 450rwhp at 15 psi. I now of a sevenin england, with the same setup that have about 430rwhp at 13-14 psi.
It will be mapped next week, so il let u know then.
Old Jul 24, 2004 | 02:52 PM
gohorns's Avatar
mine is TD06H-20G
Old Jul 24, 2004 | 03:29 PM
Just got my car fired up today with the 25G but discovered to my disappointment that the wastegate that came with the car appear to have a diaphragm or some sort of piston missing. Please look at the attached pic and let me know if something's in fact missing and if so, where I might be able to get hold of a replacement part. Many thanks.
Old Jul 24, 2004 | 05:13 PM
your mssing the whole diaphram section. i dont think greddy sells those seperatly but you might be able to use a hks diaphram. heres a good link. http://www.autosoftsys.com/supra/wgfix/
Old Jul 24, 2004 | 09:00 PM
Thank you so much for the info! You're a champ! Time to start my hunt for a HKS diaphragm.
Old Aug 9, 2004 | 09:04 PM
take some measurements of your current wastegate and diaphram before you go out and buy another one..
Good luck supracosworth..
Old Aug 9, 2004 | 11:23 PM
RETed's Avatar
NO.
-Ted
Old Mar 21, 2007 | 11:35 AM
S5rota's Avatar
Newbie
help is this a 20g or 25g td06?
Hi need some hlep identifying if this turbo is a td06 20g or 25g the housing has mitsubishi sign on it and numbers 79 14400 and it uses 3 bolt flange have posted pics at the following site below
1. http://img266.imageshack.us/my.php?i...sc00146nu3.jpg
2. http://img220.imageshack.us/my.php?i...sc00153iq7.jpg
3. http://img352.imageshack.us/my.php?i...sc00167ip2.jpg
Cheers
ls1swap
Jun 3, 2024 03:25 PM
