hello.... octane
Old Jun 18, 2004 | 01:29 AM
TechTrix's Avatar
hello.... octane
im upset to see everyone talking about afr's and no one is talking about fuel octane... when i was tuning a 91 fc with a ported cosmo, i went all the way down to 9.0 afr under heavy load 6k or so, 10 psi, and still got detonation, but this was with good old Cali 91 octane. iu put some 104 in the tank to dilute the cali crap and leaned it out to 11.0 with no problems... so remember, having a low afr # dosent mean its safe, just means its rich, wich means not all the fuel is burning, not that your car isint going to detonate or ping....
Old Jun 18, 2004 | 05:46 AM
rynberg's Avatar
You must have had a lot of other issues than the a/f ratio. There are MANY FD owners running over 350 rwhp on 91 octane gas just fine.
Old Jun 18, 2004 | 07:15 PM
coldy13's Avatar
Yeah, shutup kid.
Yeah, you probably have a timing issue. The higher octane is harder to ignite so it's combusting a bit later. Retard your timing some and see if it helps.
Old Jun 27, 2004 | 04:39 PM
TechTrix's Avatar
im at 8deg. adavnce under full load
Old Jun 27, 2004 | 05:18 PM
coldy13's Avatar
Yeah, shutup kid.
okay, retard it and see if it helps
Old Jun 27, 2004 | 09:16 PM
rxseven's Avatar
Special Dark
Well that might be a problem using 91 octane. With 0 deg. advance, I can run 89 octane at 10 psi without any issues.
Shainiac
Jul 17, 2019 02:20 PM
alphawolff
Nov 17, 2015 05:57 PM
Snook
Oct 4, 2015 08:47 PM
rx7brandon
Aug 16, 2015 10:55 AM
