how fast have you goten
Old Jun 17, 2004 | 12:01 AM
88rxrichard's Avatar
i have goten up to 145, could have gon faster but decided not to , but i did in down the 5 freeway in cali 3:00 am, so nobody was out and in the car alone 88 rx7 n/a turbo, how fast have you gotten...?
Old Jun 17, 2004 | 12:02 AM
allforjesus06's Avatar
i love assembly lube
n/a turbo? do you mean either one or a conversion?
Old Jun 17, 2004 | 12:03 AM
Syonyk's Avatar
General consensus if I remember correctly is that the speedo is usually completely inaccurate at high speeds.
That said, I've had mine to 120 before - didn't have a long enough stretch of deserted highway to crank it open, and the road was getting a bit bumpy at 120. Right now it's top speed is however fast I can push it.
-=Russ=-
Old Jun 17, 2004 | 12:07 AM
n/a a non turbo i only got an exhaust an air filter, rpm was only at 5k rpm in 5th (of course)
Old Jun 17, 2004 | 12:09 AM
i was up to ~125 (reading on speedo, don't know actual speed) on my n/a. but for the past half year, it's been at a constant 0 mph. Still trying to work out some bugs on the vacuum hoses on my fresh rebuild
Old Jun 17, 2004 | 12:10 AM
145? are you kidding?
Old Jun 17, 2004 | 12:11 AM
z4csl428's Avatar
From: Seymour, TN (couple miles west of the atlantic ocean)
in 5th (of course)
umm... 4th gear is faster, i dunno about climbing to 145 in 5th unless you were already at 145 in 4th then shifted...
z4csl428's Avatar
but ive hit 88 mph in my 91 NA then i went back in time...
Old Jun 17, 2004 | 12:12 AM
no not kidding i was pretty amaized my self, hey it regesters at 150 i bet it will go faster than that but i wanted to see if it would do what it said, hell why not
Old Jun 17, 2004 | 12:14 AM
to tell the truth its a big hill, but i still did it its the truth
Old Jun 17, 2004 | 12:15 AM
i know sounds iffy but i DID
Old Jun 17, 2004 | 12:16 AM
$150FC's Avatar
Currently Winning
i've done 150 in a volvo
i guess another way to check your speed would be to check your engine RPM and do the math...
Old Jun 17, 2004 | 12:17 AM
koukifc3s's Avatar
Clogged cat
but the speedo was prolly off...
dont really matter neway, its very unsafe to drive at those speeds.
well i did 135 once...
Old Jun 17, 2004 | 12:19 AM
the rpms dont lie 5th at 5k rpm, come on its at least up there aways
Old Jun 17, 2004 | 12:21 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
RPMs do lie. You can adjust the tacho in case you didn't know.
Santiago
Old Jun 17, 2004 | 12:22 AM
z4csl428's Avatar
the RPM's might not lie, but i think you might
flamin-roids's Avatar
Lets rock.
You must have the old flux capacitor. I got the newer one that you only have to go 35mph. Speedometers are pretty off usually by 5-10mph. According to my speedo I've gone as high as 137mph but I have a S5 auto with a 3.90 rear end which goes a little higher top end that the 4.10. Also the 5th gear on N/A trans is almost none existent.
Old Jun 17, 2004 | 12:24 AM
z4csl428's Avatar
yea i cant afford the new ones, or the old ones at that....
i had to make one
Lets rock.
Did you get the idea when you fell while trying to hang a clock?
koukifc3s's Avatar
Clogged cat
soo anyone wanna calculate how fast is 5k rpm in 5th gear?
Old Jun 17, 2004 | 12:29 AM
z4csl428's Avatar
nah smokin crack works better for me when trying to come up with ideas...
z4csI428 hey prove me wrong dont call any body a lier inless you got proof to back it up. ideas and i thinks dont cut in the real world, so unless u got actual proof i didnt hey a hill, rotary, open road, it could happen and it did so shut the f... up k
Old Jun 17, 2004 | 12:30 AM
z4csI428 nothing u say makes sence any way
Old Jun 17, 2004 | 12:33 AM
Lets rock.
Chill out dude. Your speedo may have said 145mph but it takes quite a bit to get that high. I saw a S5 TII barely run 147mph at the salt flats with a few mods. Don't take it too seriously because there are a lot of tired 7's that barely do 120mph. I think the S4 TII topped out at 138mph so thats why it seems unbelievable.
(edit: He really does have a flux capacitor I ran into him earlier this century.)
