1988 n/a problems
Old Jun 15, 2004 | 02:45 PM
earl's Avatar
Newbie
Question 1988 n/a problems
I have a 88 N/A convert. this is my second engine installed I,m having the same problems with this as the last
1st) will not idle starts up fine goes to 3gs comes down
to 1g then cuts off.
2nd) I saw a red glow at the oxygen sensor
3rd) I have tryed everything to get this car to idle long enough to set the timing
most recent cant get the starter to work, had it checked
they said it was fine
please help out.
Old Jun 15, 2004 | 03:36 PM
J-Rat's Avatar
Alcohol Fueled!
How are you checking timing before startup? There is a method you can use to get the CAS dead on, before you start..
Search for Timing
The1Sun
Sep 15, 2015 04:45 PM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
mulcryant
Sep 9, 2015 05:24 PM
