anybody ever use something beside the $60 downpipe gasket
Old Jun 15, 2004 | 12:03 AM
calio64's Avatar
im probably getting a garret turbo for the FC within the next couple months and im thinking the downpipe flange is going to be diffrent then our stock flange,the downpipe gasket i have now is shot and i dont really wanna spend 60 bux for a new gasket so i was wondering if anybody has done something that is a little cheaper, ive seen some header gasket maker at discount auto parts and im wondering if this silicone will with stand the heat from the turbine, i was checking to see if anybody has tried this stuff
thanx alot for any info
Old Jun 15, 2004 | 12:51 AM
neofreak's Avatar
accept no imitations™
just use the factory one, don't waste your time with anything else.
the time it takes you to put on and take off a cheaper "solution" already makes it cost more.
time = money.
Old Jun 15, 2004 | 12:54 AM
White_FC's Avatar
Personally I had both of the surfaces(DP and Turbo housing) machined flat and then just used a tiny bead of exhaust sealant. Never leaked at all.
Thats what I did anyway...
fc3seeker's Avatar
T2 Noob.
With the amount of heat thats involved I wouldn't go with anything else but the factory gasket.
