bad ecu or blown seal?
Old Jun 14, 2004 | 07:41 PM
KingCobraV9's Avatar
Rotary engine victory
Question bad ecu or blown seal?
hey all i was wondering how you would know if u had blown an apex seal? like just one on one rotar. would it wake a noise? and is it possable for just one to go.
also my car dies when i stop w/ the ac on sometimes. and when i first start the car i have to give it gas or it will die. not allot just toush it when the idle starts to drop. i do that twice usually then it will idle ok.
what in the world is going on? thanks ahead of time.
Old Jun 14, 2004 | 07:47 PM
WAYNE88N/A's Avatar
If in doubt, do a compression check (search)...I doubt you have a blown apex seal, if you're still driving it around with any power at all...check all around the engine compartment for vac leaks, and check all the normal stuff (BAC valve,TPS,plugs,filters,etc...)
cristoDathird
28
May 30, 2019 08:47 PM
Jmolina0163
Oct 3, 2015 10:04 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
JZW
20B Forum
Aug 18, 2015 08:56 PM
