Intermittent no start, is still intermittent...
Old Jun 14, 2004 | 06:07 PM
harley71105's Avatar
Arrow Intermittent no start, is still intermittent...
During the past three no starts I removed the air filter and she fired right up...then...on the last one she did not...
I've tried everything else....maybe its just a sometimes malfunctioning fuel pressure regulator....Geeeezzz.....
Old Jun 14, 2004 | 06:27 PM
WAYNE88N/A's Avatar
Hey Harley, I was wondering when you'd be back, lol...What are all the things you've checked out on the car lately?
Old Jun 14, 2004 | 07:00 PM
WAYNE88N/A's Avatar
You know what you really need to do- uncover your ECU over there on the passenger side, and keep it oncovered till we figure this out...Go the page 4A-30 of the FSM, there are several pins that can be "backprobed" with just the key on, not running...Make a list of these items, and which pins to read out, and keep it in the seat beside you...Next time she no-starts, leave the key on, & start probing...The important ones I would hit first are:
1) 2A- ECU 5 volt output to the sensors
2) 3C,3E,3F,3H- injector voltage
3) 3I- main relay
There are also coil/igniter signals (may have to be running for these), CAS inputs (same), and several others that ought to give you a clue as to what's going on...
See FSM page 4A-32 for pin locations...
Old Jun 14, 2004 | 08:17 PM
Hello Wayne. You may be getting to something here, but if it pertains to ECU's I've had both my spares in this car and it does the same thing....
I have noticed that once I crank it for say 3-5 minutes, I can wait for 20-30 minutes and she will fire right up....
Old Jun 14, 2004 | 08:24 PM
WAYNE88N/A's Avatar
No, I'm not saying you have a bad ECU- I'm saying you need to read out as many inputs as you can during the time the car's kaput- and the best place to do that is at the ECU...You can read out virtually the entire engine electrical system from that point...You can even drive around with a probe on whatever pin you choose and check out the entire system in a couple of days (it's pretty cool watching your injectors' duty cycles, O2 sensor outputs, AFM outputs, etc...)
Old Jun 14, 2004 | 09:27 PM
J-Rat's Avatar
Alcohol Fueled!
can we get a recap of what you have done?
rx7jocke
72
Jun 17, 2016 03:48 AM
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
