custom belly pan
Old Jun 12, 2004 | 08:46 PM
black93RX7's Avatar
20BFD
custom belly pan
I just installed a new rad and IC and the stock belly pan will not fit back on. I am wondering what others have done about this issue. How important is the belly pan for directing air to the rad?
Thanks for any help
Old Jun 12, 2004 | 09:38 PM
r71's Avatar
r71
You gotta cut it.
Old Jun 13, 2004 | 01:24 AM
black93RX7's Avatar
20BFD
Do you mean just make it fit?
Old Jun 13, 2004 | 12:11 PM
SnowmanSteiner's Avatar
Ga-nome liberator
The best way is to create a new pan out of alluminum or sheet metal, with proper support, that blocks off the entire engine bay except for where you want air to flow out.
- Steiner
Old Jun 13, 2004 | 02:43 PM
black93RX7's Avatar
20BFD
Thanks for the advice, does anyone have pics of a custom belly pan by any chance?
Old Jun 13, 2004 | 08:56 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
the bellypan is an important component as to cooling. i recommend you spend some serious think-time refixturing it so air goes thru your water radiator and not around it.
good luck
howard coleman
Old Jun 13, 2004 | 09:17 PM
black93RX7's Avatar
20BFD
When I get the car back I will see what I can fabricate. My temps stayed between 84C amd 86C without the belly pan on but I was staying under 4psi and under 5000rpm during the break in period. I have a fmic so I am concerned with temps once I start getting on the boost.
Thanks again for the help
Erik
Old Jun 13, 2004 | 09:26 PM
Broken09's Avatar
I am becoming...
I'm working on a belly pan now. I'll be finishing the design hopefully in the next couple of weeks and then routing it at work once I get the shape. If I get enough interest I may produce more of them.
-Nic
Old Jun 13, 2004 | 09:47 PM
black93RX7's Avatar
20BFD
depending on what I can do and the cost I might be interested.
Erik
Old Jun 14, 2004 | 02:05 AM
c00lduke's Avatar
same
Old Jun 14, 2004 | 08:16 AM
Broken09's Avatar
I am becoming...
I'd like to get price down in the range of 200 but it depends also on what type and thickness aluminum I use. I will be able to get different types and thicknesses from the supplier down the road it's just a matter of how much you want to pay as well. Hopefully with enough interest I could buy a few sheets at one time as well and save some money that way. I will post pics when mine is complete.
-Nic
tiger18
Sep 3, 2015 08:27 PM
