Help!!! Alarm Won't Shut Off
Old Nov 10, 2001 | 06:49 PM
WhiteN/A's Avatar
Angry Help!!! Alarm Won't Shut Off
I didn't think my alarm worked so I checked it by rolling down the widow, locking the doors and then I reached in through the window and unlocked the door. I then opened the door from the outside and the thing went crazy. I couldn't get it to shut off, I tried everything, I finally had to disconnect the battery. So my question is how do you turn off the alarm without having to disconnect the battery? I have an '88 SE, I just got it and it was the first time using the alarm
Old Nov 10, 2001 | 06:55 PM
wReX's Avatar
Does not drive a WRX!!!
Haha! I did that when I first got my car too. That alarm still scares the **** out of me when it goes off. Anyways, on my '91 the alarm is turned off when you turn the key in the door.
Old Nov 10, 2001 | 07:05 PM
WhiteN/A's Avatar
I will have to try that, I tried to start it like 50 times to get it to shut off, but that didn't work. Does it have a thing that disengages the starter or something?
Old Nov 10, 2001 | 07:20 PM
wReX's Avatar
Not sure if it cuts the motor too, but I am guessing that it should. Also, if I were you, I would put some sort of kill switch in your car. RX7's are not very hard to steal and I wouldn't rely on the factory alarm. I will try to post some pics of my kill switch tomorrow.
Old Nov 10, 2001 | 07:23 PM
Scott 89t2's Avatar
SOLD THE RX-7!
LOL, yeah it disages the starter. just stick the key in the door and unlock it, you might have to lock it from the inside first.
I had mine go off once when i unlocked and opened the driver side door with the key. I spent a few mins trying to get it to turn off, (at 11:30 at night infront of friends house...) lock doors, close, unlock, try to start car, ect. I finaly went around and unlocked the pass side door and it turned off. my alarm wires that connect to the driver side lock had come off.
squirrels
Sep 1, 2024 09:52 AM
lnlreaper
Sep 27, 2015 09:59 AM
rattlehead
Sep 25, 2015 10:55 PM
ls1swap
15
Sep 8, 2015 05:30 PM
