headlights wont go up or on
Old Jun 10, 2004 | 04:25 PM
MicahMan's Avatar
That's Nice!!!!
Angry headlights wont go up or on
they worked before and now i took my switch off and cleaned all the contacts and put it back together and put the switch on and then it worked for a while then i went to check it again and the lights wouldnt go up or on. i took the switch off again and cleaned it another time and still had the same problem. and the fuse is good. im pissed. what am i doing wrong is there another fuse somewhere or may it be a relay? i can manualy put the lights up and when i flip the center counsel switch they go down but wont go up. im so confused. please help.
thanks
Old Jun 10, 2004 | 05:03 PM
85rotarypower's Avatar
love the braaaap
Sounds like your switch just went bad. Try a different one if you can.
Old Jun 10, 2004 | 06:39 PM
Makwana's Avatar
Yup it sounds like the switch has gone bad.
Old Jun 10, 2004 | 08:03 PM
gonzz's Avatar
You can also check the fusible links..
Old Jun 11, 2004 | 03:22 PM
MicahMan's Avatar
That's Nice!!!!
where is the fusable link?
Old Jun 11, 2004 | 03:24 PM
MicahMan's Avatar
That's Nice!!!!
Old Jun 11, 2004 | 03:40 PM
jason_child's Avatar
fusible links
eithier under the dash on the headlight motor or on the fender wall next to the battery wire in black thread attached to a brown boxy thing hope that helps
Old Jun 11, 2004 | 04:03 PM
Bob Holton's Avatar
recycled teenager
fuseable link on an 85GS is inside the fender just ahead of the strut tower drivers side soft covered loops , three in and out of a box, Then check the grounds then a switch. Been there and done that ,, wiggle everything on the light harness.
Old Jun 11, 2004 | 04:17 PM
MicahMan's Avatar
That's Nice!!!!
ok ill try that
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
