17x8.5 too small in the back?
Old Nov 10, 2001 | 01:03 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
subject says it all......would taht size be too small in the back of an FD? I have 17x9 right now and by putting 8.5s in the back could you tell a difference? thanks
Old Nov 10, 2001 | 01:23 PM
JoeD's Avatar
Re: 17x8.5 too small in the back?
why do you want to do this?? less weight?? the weight difference between a 17x8.5 and 17x9 is barely noticable on a scale, let alone on your car. its not worth it. or, do you run the same sized tires front and back??
go with some 17x10s on the back so you can run 285/35 tires!
Old Nov 10, 2001 | 06:52 PM
RX7 RAGE's Avatar
Top Answer: 1
Re: Re: 17x8.5 too small in the back?
thanks for the advice..but I don't think they make se37ks in 17x10 do they?
Old Nov 10, 2001 | 07:35 PM
maxcooper's Avatar
WWFSMD
I would go with one of these combinations:
8.5F 9.5R (this is what I use on the street)
9F 9R (Taz has this size, and you can use the same tires on all 4)
9F 9.5R
The price of the wheels does not change much with width, and you might as well get as much rubber as you can on the road.
Old Nov 10, 2001 | 10:21 PM
JoeD's Avatar
Re: Re: Re: 17x8.5 too small in the back?
did you even mention SE-37Ks in your post. no.
get 17x9.5s.
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
alphawolff
Nov 17, 2015 05:57 PM
