RX6 Oil Inlet fitting needed bad!
Old Jun 8, 2004 | 02:14 AM
Indo Audio's Avatar
Mine broke due to overtightning, just snapped. This is the oil inlet with a 10 mm 1.5thread to a -4 an fitting. This fitting also has the oil restictor jet on it, so it would be impossible to get at a hose shop. Please let me know if anyone has suggestions, etc.
Thanks,
Ravi
Old Jun 8, 2004 | 06:59 AM
Michael Filippello's Avatar
I did the same thing when I first installed my kit. just give apexi USA a call. hopefully they will have it in stock, otherwise you will have to wait for it to come from japan.
mike
Old Jun 8, 2004 | 07:45 AM
Indo Audio's Avatar
they don't have it in stock unfortunatly. Any other suggestions?
Old Jun 8, 2004 | 11:53 PM
tkuwaha's Avatar
I think Earl's makes a fitting in that size(no restrictor though). You can probably restrict the oil flow with a pill similar to stock wastegate line pill or a carb jet.
Old Jun 9, 2004 | 11:34 AM
vspecpgt's Avatar
yup, apexkw had to order one through apex usa..... it sucked, took like 3 months and was such a hassle...... best thing to do would be to just get a normal earls fitting, have the top brazened up (welded) and then just drill a small hole in the weld the same size as the stock hole.... or try using a pill, that might work good too......
Jmolina0163
Oct 3, 2015 10:04 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
