How much clearance between the chassis and the turbo is sufficient?
Old Jun 7, 2004 | 10:22 PM
CCarlisi's Avatar
Rebreaking things
How much clearance between the chassis and the turbo is sufficient? I have just over 1/4” between the chassis and the compressor and am concerned that the compressor will make contact with the chassis when the motor twists under load. Bear in mind the engine has eurathane motor mounts.
Old Jun 7, 2004 | 10:31 PM
Broken09's Avatar
I am becoming...
Some kits I've seen have as little as that. The fabricators of those kits suggest getting a torque brace in many instances.
-Nic
Old Jun 7, 2004 | 10:52 PM
peejay's Avatar
Old [Sch|F]ool
How much does the engine move?
1/4" would have me worried, urethane mounts or no. 1" at a bare minimum.
Old Jun 7, 2004 | 11:20 PM
IRPerformance's Avatar
Sponsor
Take a large pry bar and pry under the mount. That should give you an idea of how much the engine moves. In my opinion a torque brace is a ghetto bandaid solution to the real problem, weak motor mounts.
Old Jun 8, 2004 | 03:15 AM
twokrx7's Avatar
Need more sleep
Should not be an issue with your motor mounts but for insurance you could "clearance" the rail ... beat the hell out of it to give some more room for the turbo.
Old Jun 8, 2004 | 11:23 AM
felix_is_alive's Avatar
i know this might sound very barbaric but....blow-torch and sledgehammer!!.....then repaint
Old Jun 8, 2004 | 11:44 AM
CCarlisi's Avatar
Rebreaking things
Thanks for the input guys. If I need more room I'll have the manifold turbo flange tilted towards the motor slightly. I'd rather pay for a couple hours of labor to do that than try to adapt the chassis to fit a poorly designed part.
However, with that said I'm still not sure how much clearance I need. Peejay suggested 1" What do the rest of you think-is 1" too much, too little? For those of you that are curious, I posted pictures of the turbo mounted on the manifold in my single turbo thread on nopistons
Old Jun 12, 2004 | 11:34 PM
zkeller's Avatar
Quarter inch. That's more than I have and I have no hitting problems and I have stock motor mounts. Which kit do you have Chris?
Old Jun 13, 2004 | 01:40 AM
CCarlisi's Avatar
Rebreaking things
That is good to hear. Thats for your input. I'm using a T04s with a 35R compressor and one of the infamous Autochrome manifolds.
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
