Replacing a air pump
Old Nov 9, 2001 | 07:35 PM
C2MaZdaRX7's Avatar
Newbie
Question Replacing a air pump
I was wondering if you guys had any tips on replacing a air pump on my 95 mazda rx7. Also do you guys know if a bad air pump with affect the performance of my car. Thanks.
Old Nov 9, 2001 | 08:27 PM
rx7ofmine's Avatar
A bad airpump will not hinder the performance of you car initially, but through time your main cat will clog causing restrictions in the exhaust. And depending on where you live, you probably will not pass smog. Find youself another one from the parts for sale section or from www.thepartstrader.com, good luck
Old Nov 9, 2001 | 08:28 PM
ZoomZoom's Avatar
SEMI-PRO
Well for one your in cali so you need a functioning Air pump. As for your second question. Yes it will effect your cars performance. The air pump actually provides secondary air injection at low rpms. If the air pump is unplugged you will have to turn your Idle Air contril screw way up just to get it to idle right. Also light throttle will dog without an airpump. Not to mention fouled plugs like mad.
Old Nov 25, 2001 | 10:17 PM
GoRacer's Avatar
Speed Mach Go Go Go
Red face Air pumps sucks
I had to have mine replaced. I was charged $450 for a used one from Rotary Reliability. A new one is over $1,000 but they had it installed before I had a chance to search parts trader or junk yards.
I have a Greddy Pully kit that can bypass it, but from the other posts sounds like I will leave it connected.
Skeese
65
Mar 28, 2017 03:30 PM
alphawolff
Nov 17, 2015 05:57 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
