Newbee Turbo Question
Old May 31, 2004 | 11:08 AM
teachermechanic's Avatar
Hi, my turbo is 62-1 with .96 turbine housing.
I want to put bigger turbine side like 1.00 or more.
I need to change turbine wheel and housing or just housing?
Thanks
Old Jun 1, 2004 | 06:48 PM
nobody know?????????????
Old Jun 1, 2004 | 07:10 PM
black99's Avatar
Lurking..................
I believe you mean .96 HOT side or so I would assume. I think all you need to do is get an exhaust housing that's for the same trim(O, P, or Q) exhaust wheel in the size you want. I haven't seen 1.00 exhaust sides on anything other that HKS or XS stuff, however 1.15 is common.
Although maybe someone who's actually swapped them out will check in.
Old Jun 2, 2004 | 07:57 AM
It's right Black99, i thing 1.15 is common size.
I don't want to command wheel if i just need to change housing.
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
