quick question
Old May 27, 2004 | 09:51 PM
-FD-in-FC-'s Avatar
quick question
what is the stock boost pressure of and FD
and does anyone know what a mines ecu upgrade raises it too
any info would help thanks
Old May 27, 2004 | 09:52 PM
DrunkenBowler's Avatar
Boost pattern should be 10-8-10.
Old May 27, 2004 | 09:53 PM
Mahjik's Avatar
Mr. Links
Arrow
http://www.scuderiaciriani.com/rx7/boost_test.html
Old May 27, 2004 | 09:58 PM
-FD-in-FC-'s Avatar
thanks
now can anyone help with the Mine's ecu question
this thing is hard to get info on
Old May 27, 2004 | 10:05 PM
Mahjik's Avatar
Mr. Links
Generally, the ECU doesn't "raise boost" itself.
Your boost is limited by the amount of fuel you are able to supply for a safe A/F ratio. As far as I know, no 3rd gen owner on the forum here is using a Mine's ECU. However, as they are a chip programmer, the ECU could be programmed to support whatever mods you had.
The stock map sensor is limited to about 17 PSI. So, if you had the ECU fuel mapping, enough CFM and the proper A/F ratio you could run 17 PSI.
The amount of boost you can run is dependent on more components than just the ECU.
Old May 27, 2004 | 10:21 PM
-FD-in-FC-'s Avatar
well the motor is really fast
and the guy i got it from is crazy and just laughs when i ask him to tell me what is done to it
i blew the turbos up and am now going single so i am tryin to figure out what i should do for a wastegate
i have an upgraded fuel pump and lots of other goodies but i was hoping to get more info on the ecu
thanks for the quick replyz
Old May 27, 2004 | 10:26 PM
-FD-in-FC-'s Avatar
and the guy i got it from is crazy (in a good way) and just laughs when i ask him to tell me what is done to it
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
