How the heck do you read a turbine map?
Old May 27, 2004 | 02:26 PM
Barwick's Avatar
SCCA Rookie
I know compressor maps, they're easy to understand (there's plenty out there on how to read them), but I have no clue what each turbine map means.
Anyone have any resources?
Old May 29, 2004 | 03:27 PM
Barwick's Avatar
SCCA Rookie
nobody knows this answer on here? No way.
Old Jun 10, 2004 | 08:37 AM
Barwick's Avatar
SCCA Rookie
anybody...
Old Jun 10, 2004 | 01:47 PM
FC Alex's Avatar
I'm pretty sure that you read the inner circle. That's where the turbo is most efficient, in that range. Ussually it's some were near 74%, that range tells you were the turbo is efficient. After you leave the inner circle your turbo losses efficiency (power), which often happens with smaller turbo's. For example on a t25 though you're boosting 18 psi you're making less power than you were at 14 psi, because the turbo is not really efficient passed 15 psi.
Old Jun 10, 2004 | 01:52 PM
CCarlisi's Avatar
Rebreaking things
Take a look at this page.
http://cybrina.mine.nu/MR2_Docs/comp..._flow_maps.htm
Old Jun 10, 2004 | 05:16 PM
Zero R's Avatar
Just in time to die
The turbine map is what you'd use after you've plotted the compressor map to find your speeds and efficiencies.
Old Jun 10, 2004 | 08:30 PM
eViLRotor's Avatar
Brother of the Rotary
Excellent Link, thanks
Old Jun 15, 2004 | 01:11 PM
Barwick's Avatar
SCCA Rookie
I know how to read a compressor map.
I'm talking about a turbine map.
That link seems to help a little bit, with the exducer bore information, but doesn't say anything about the turbine map.
dillrx7
Sep 7, 2015 09:38 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
befarrer
Sep 4, 2015 08:26 PM
apooch
Sep 4, 2015 10:27 AM
