Power FC Real Time Tuning Possible Or Not?????
Old May 23, 2004 | 06:48 AM
Power_Put's Avatar
IS IT POSSIBLE TO REAL TIME TUNE THE POWER FC WHILE DRIVING WITH THE COMMANDER OR A DATALOGIT WITHOUT SWITCHING OF THE ENGINE
IVE HEARD MOST STANDALONE ECU DOES REAL TIME TUNING
THANKS FOR ANY HELP
Old May 23, 2004 | 08:24 AM
cewrx7r1's Avatar
Eye In The Sky
You can real time tune with the COMMANDER and DATALOGIT while driving. Best to have a buudy with you.
You drive. He monitors and makes changes. Safer that way.
Old May 23, 2004 | 09:37 AM
Power_Put's Avatar
THANKS cewrx7r1 so its possible with the datalogit and laptop. (setttled)
So the commander alone is not able to do this work? wright............. !!!!!!!!!!!!!?
because if im not mistaken Apexi said in the fc commander manual you must switch of the car before changing setting etc with the FC COMMANDER .....!!!
Old May 23, 2004 | 03:33 PM
cewrx7r1's Avatar
Eye In The Sky
And with the commander. The DATALOGIT with laptop allows tuning fields not accessable with the ccommander and has logging capabilities.
Old May 23, 2004 | 10:37 PM
Power_Put's Avatar
ok cewrx7r1 thanks for the help again
Old May 26, 2004 | 06:22 PM
jpandes's Avatar
I've made changes from the commander to my fuel maps while the engine was running. Basically to smooth out the idle.
Old May 29, 2004 | 07:14 AM
LT1-7's Avatar
John
if you change timing maps you must turn the ignition and turn back on for it to save
Jun 26, 2016 10:21 AM
MoTeC
Sep 10, 2015 07:58 PM
Microtech
Aug 23, 2015 11:04 AM
Wolf_
Aug 11, 2015 04:23 PM
