Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
n/b vs w/b O2
Old May 20, 2004 | 08:32 PM
chuck8313BTSDS's Avatar
n/b vs w/b O2
Posted this in the other forum also.
Dataloged a 4wire heated Honda and a PLX 0-5 volt out w/b O2's. The Greddy E-O1 logs every 10th of a second. The N/B heated O2 voltage range the Greddy would log was from .70 to 1 volt. The Greddy was set to read the PLX voltage from 0 to 6.5 to get a smother line. The photo clearly shows the narrow band O2 follows the PLX voltage reading when the motor went rich or lean. In the photo the bottom line is the PLX and top is the heated O2. When the PLX voltage reads a higher voltage (lean) the heated O2 voltage falls at the same rate/as fast. I think the W/B make me lazy diagnosing a miss fire problem. With the N/B I had to think if it was a rich or lean miss fire where the W/B says rich or lean. The N/B voltage just goes to zero on all miss fires because it only judges AFR by the amount of oxygen in the exhaust. Rich or lean miss fires have lots of oxygen. But in my opinion as long as the motor is running fairly good the AFR's can be monitored with an N/B O2 with confidence. Most rotary motor will idle around 12.00AFR's. If the N/B voltage reads a given number for idle then under low boost numbers the N/B voltage should be no less then .05 to.07 volts more. My N/B voltage at idle is .83 while the PLX shows a 12.1afr. When the PLX shows a afr in the low 11's the n/b voltage is in the .92 or range. Every N/B O2 will read differently from each other but only by tenths of a volt. Is what I did once was put the car on a dyno and monitored the dyno AFR's and compared them to my egt number and N/B voltage. Tuned my motor to run some good numbers at the track like this. I also have been looking at N/B voltage reading for a very long time using a O-scope, that helped allot. Just thought I would throw this out there to stir up some controversy. Link below shows the datalog.
chuck
http://groups.msn.com/ChucksRX7/1987...to&PhotoID=552
The Shaolin
Sep 14, 2015 07:50 PM
ronbros3
Microtech
Jun 29, 2011 10:03 PM
spot_skater
Haltech Forum
22
Jan 23, 2009 09:39 PM
vrracing
11
Oct 28, 2008 09:25 AM
twister7
Megasquirt Forum
15
Feb 4, 2007 03:50 PM
