last try, hope you guys will still help me
Old May 19, 2004 | 07:30 PM
frigidmonkey's Avatar
rotor withdrawal
You guys have been great so far. And what I'm going to do, I KNOW is something that most of you don't recommend. I can't afford to get a new holley (don't think I'd want one at this point) I definitely cant afford a weber and manifold, or a dellorto and manifold. So, what I plan on doing is cutting a groove between the primaries on my RB manifold, getting a 500 cfm Edelbrock, and a bunch of jets. I don't mind making adjustments, tuning for me is actually fun if I feel like I'm making progress. I just know that I'm going to have a LOT of questions and I'm hoping you guys will still be willing to answer :]
hey at least I'm not putting a v8 in it :P
Old May 19, 2004 | 08:02 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Why don't you just get a Sterling Carb?
Old May 19, 2004 | 08:15 PM
85rotarypower's Avatar
love the braaaap
I'm with sterling on this. Its tons better than that craptastic edelbrock. If anything try the 465 cfm holley that RB uses. Loads cheaper and probably better on gas. 500 cfm is useless anyway unless you have a ported engine. The max recommended size for a stockport is the holley 465cfm carb with vacuum secondaries. I'm actually thinking about this. The only real problem is the oil injection. Since there are no bungs in the holley/edelbrock, you will have to design your own system. The only other thing is that you might have to spend weeks on end trying different jet combinations to get it to run right.
BTW, you can pick up the holley through Jegs. Its not the rotary specific one though. Only RB has those because they mod them to some great extent.
Old May 19, 2004 | 08:23 PM
love the braaaap
Oops. Just checked jegs and they don't sell them any more. They do sell a very interesting 350 cfm 2 barrel carb for <$250. This might work well for a small increase in power. Easy to tune too since its only a 2 barrel.
Old May 19, 2004 | 08:37 PM
rototiller1's Avatar
Inspector, Falcon Jet
Do a search on edelbrook, you will fine my posts, it has all the jet info you need, theres nothing wrong with this carb choice, mines a 625 cfm
Old May 19, 2004 | 08:38 PM
Old May 19, 2004 | 08:40 PM
search edelbrook, you will find my posts, with jet selections
Old May 19, 2004 | 09:26 PM
rotor withdrawal
I can't afford a sterling carb, can't wait that long for one either. As far as the racing beat holley, that's what I'm trying to get away from, and I can't afford one anyway, I can barely get the money together for the edelbrock. 225 for edlebrok vs 500 plus for the RB holley..
as far as the oil lines, I already run premix
Old May 19, 2004 | 10:46 PM
love the braaaap
Oh ok. The holley from Jegs is $300. IMO, its a better carb. But if the jet sizes and everything are already documented for the edelbrock, then use it. Less messing around then.
Old May 19, 2004 | 10:48 PM
rotor withdrawal
I'm sorry guys, I'm not trying to offend anyone, I just had a VERY bad 10 day long experience with the holley, and I'd love it if I never saw one again
Old May 19, 2004 | 11:47 PM
rotor withdrawal
I did a search, I'm not finding the jet selections
Old May 19, 2004 | 11:59 PM
bstrange99's Avatar
unregistered rex offender
How much for a sterling carb?
Old May 20, 2004 | 07:37 AM
Sterling's Avatar
$350
Old May 20, 2004 | 08:40 AM
rotor withdrawal
am I going to need an FPR with that edelbrock? I know its a good idea, but do I need one right away?
Old May 20, 2004 | 11:32 AM
love the braaaap
You will need an aftermarket fuel pump and pressure regulator. I found the post about the edelbrock, but its bookmarked on my other computer. I'll post it when I get to the computer.
Old May 20, 2004 | 11:45 AM
love the braaaap
Here it is.
https://www.rx7club.com/showthread.p...ight=Edelbrock
Old May 20, 2004 | 01:15 PM
rotor withdrawal
thanks rotory power
now I just have to scrape together the money for a fuel pump and regulator, the guy that had it before me wasnt running either on the holley.
and suggestions on which pump and regulator to get?
Old May 20, 2004 | 01:24 PM
love the braaaap
FYI, the stock pump won't cut it. It doesn't flow nearly enough for any kind of aftermarket carb. It barely flows enough for the stock carb from what I hear.
As for a pump, I would suggest the holley blue pump. It comes with a regulator and flows more than enough for the edelbrock. I'm seriously thinking about this also at this point. My carb is just seriously f***ed up and I can't seem to fix it (BTW, rx7carl, if you see this, it isn't the solenoid). I just want a cheap way to get my car running properly.
Old May 20, 2004 | 01:31 PM
love the braaaap
Rotortiller1, did you ever fix some of the problems? I think all of us would like to know.
Old May 20, 2004 | 03:57 PM
Jeff20B's Avatar
Lapping = Fapping
I don't know if this will help. https://www.rx7club.com/forum/showth...hreadid=285741
Tylerx7fb
39
May 27, 2019 12:45 PM
Leeroy_25
Aug 17, 2015 12:53 PM
Clacor
Aug 14, 2015 09:17 AM
