Questions for the turbo guys.
Old May 19, 2004 | 10:20 AM
13BTOY's Avatar
Boosted Fb
Looks like I'm going to boost my carbed SE motor after all. I'll be using the Dellorto thats on the car now and an S4 turbo and manifold. Looking make 10psi. Just a couple of questions so I can get my plans laid out.
1. Can I use the nipple on the rear housing and the nipple behind the water pump housing for the water lines going in and out of the turbo?
2. Are there any other oil source for the turbo other than using the RB oil adapter and tapping the front cover for the return? I could of sworn I saw someone post a pic with the oil lines going to the oil cooler line. If your reading this please contact me!
3.What timing should I run? I'd like to get my distributor locked for accuracy and most of all safety. Who here can do it? Please contact me!
4. How much boost would the stock wastegate put out? Does it have to be ported?
5. Do I need an intercooler for this set up? I plan to run without one first until I get a front mount.
I welcome any other suggestions, tips and tricks you guys might have. Please feel free to throw your .2 cents in!
Thanks, Ed
Old May 19, 2004 | 12:09 PM
web777's Avatar
Re: Questions for the turbo guys.
You can tap the banjo fitting on the rear oil cooler hose. But I think it's easier and better (closer to turbo) to use the RB block.
Old May 19, 2004 | 12:27 PM
GOOFYROTOR's Avatar
cams pistons valves
BLITZ has a round oil adapter.
why do u want to use the oil lines? turbo return needs to be drained to oil pan ASAP.usually its directly to the oil pan.
Old May 19, 2004 | 12:38 PM
web777's Avatar
I think he meant tappin the oil return to the front cover.
Old May 19, 2004 | 02:45 PM
13BTOY's Avatar
Boosted Fb
Yep! Thats what I meant.
Thanks, Ed
Old May 19, 2004 | 03:09 PM
seanrot's Avatar
Always waiting for parts!
If you have a 84~85 engine you can take the oil presure sensor out and go to a hardware store and get a 1/8 npt T fitting and tap a oil feed line off that.
I can lock you distibuter for you, pm me
Old May 19, 2004 | 03:13 PM
eddierotary's Avatar
back with rotaries
first of all , you wanna check my website that is www.cardomain.com/id/eddierotary it will tell you what i did when i had my turboed gslse carbed engine. and i will recomend to use a intercooler, and for the water lines, one thing that helped me alot was a turbo II water pump housing, the dizzy you can locked it, but i recomend to leave it open but at 0 degree leading so it doesnt advance alot. and for last the S4 turbo tend to boost creep. but with a good ported WG and a 2.5 inch exhaust it will somewhat stay at 12 psi.
Old May 19, 2004 | 06:43 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
i would suggest a s5 turbo setup also,
its harder to find, and a bit more expensive, but it will make more power and run better,
s4s have a complicated flapper door system that I have heard is a big pain in the *** to deal with
Old May 19, 2004 | 07:54 PM
680RWHP12A's Avatar
the s4 turbos will make great power too you just need to port the wastegate and remove the flapper and weld up the hole... it will work just as good
Old May 19, 2004 | 08:06 PM
680RWHP12A's Avatar
[B]Looks like I'm going to boost my carbed SE motor after all. I'll be using the Dellorto thats on the car now and an S4 turbo and manifold. Looking make 10psi. Just a couple of questions so I can get my plans laid out.
1. Can I use the nipple on the rear housing and the nipple behind the water pump housing for the water lines going in and out of the turbo?....yes
2. Are there any other oil source for the turbo other than using the RB oil adapter and tapping the front cover for the return? I could of sworn I saw someone post a pic with the oil lines going to the oil cooler line. If your reading this please contact me!........ yes install a T fitting where the oil pressure sender is, oil domp into the front cover below the OMP
3.What timing should I run? I'd like to get my distributor locked for accuracy and most of all safety. Who here can do it? Please contact me!... .....lock the dizzy and set the timing at 10 deg. total adv...leading and trailing
4. How much boost would the stock wastegate put out? Does it have to be ported?.......what year turbo are you using?
5. Do I need an intercooler for this set up? I plan to run without one first until I get a front mount.........no you dont need one
I welcome any other suggestions, tips and tricks you guys might have. Please feel free to throw your .2 cents in! i have a bag of tricks!!! e-mail me
Old May 19, 2004 | 08:10 PM
you dont have to run water lines do you? thats just a extra thing right?
Old May 19, 2004 | 08:34 PM
the divided exhaust housing and manifold must be an advantange vs the s4 setup.
not to say that the s4 is bad, it just seams like the s5 is a better option.
Old May 19, 2004 | 09:57 PM
13BTOY's Avatar
Boosted Fb
Guys, thanks for all the response! keep em coming!
I originally wanted a s5 set up but this is what I have to work with. i also have a volvo ic but wnted to simplify the install and bolt the ic on after its running? Any suggestions on a fuel pump to go along the mallory 4309 pressure regulator?
Thanks, Ed
Old May 19, 2004 | 10:13 PM
85rotarypower's Avatar
love the braaaap
I would suggest a holley red fuel pump. Should be plenty for your setup.
Old May 19, 2004 | 11:17 PM
13BTOY's Avatar
Boosted Fb
I'm running a Holley Blue right now. Where do I get my oil lines from?
Thanks, Ed
Old May 19, 2004 | 11:37 PM
13BTOY's Avatar
Boosted Fb
Just finished checking out Eddierotary's sight and noticed that he mentioned something about the turbo II manifold needing an adapter to work with the SE intake? Please clarify. I thought it was a bolt on affair?
Thanks, Ed
Old May 20, 2004 | 01:16 AM
web777's Avatar
The turbo will hit the SE lower manifold (bigger from the actuators).
Also, you will need and EFI fuel pump. The Holley's are only good for NA carbs.
Old May 20, 2004 | 01:46 AM
680RWHP12A's Avatar
please talk to eddierotary.....he has already done this turbo swap, he can help for sure!!
Old May 20, 2004 | 08:35 AM
13BTOY's Avatar
Boosted Fb
I'm not running the 6 port actuators. My intake is gutted of all mechanism. Will I still have clearance problems? EFI fuel pump for NA or Turbo? I hear of people using the stock SE pumps so I'm assuning NA will suffice?
Thanks, Ed
Old May 20, 2004 | 08:58 AM
13BTOY's Avatar
Boosted Fb
Which carb hat should I get from CB for my dellorto? Left hand side inlet for offset or no offset manifold?
Thanks, Ed
Old May 21, 2004 | 08:50 AM
13BTOY's Avatar
Boosted Fb
I guess I need an s4 lower manifold for the swap. How hard is it to port the wastegate?
Thanks, Ed
Old May 21, 2004 | 08:56 AM
13BTOY's Avatar
Boosted Fb
Eddierotary, what did you do to the injector holes on the intake?
Thanks, Ed
Old May 21, 2004 | 04:28 PM
680RWHP12A's Avatar
Thanks, Ed
injector plugs
Old May 21, 2004 | 09:15 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
The oil return line from the turbo should be the closest to the pan as possible. I believe it's gravity fed and the quicker you get the oil out of the turbo when shutting the car down the better.
Old May 21, 2004 | 10:28 PM
13BTOY's Avatar
Boosted Fb
Do I use the Racing beat ones like the ones I used on the housings? But how would they stay place? The ones on the housings are held down with a plate?
Thanks, Ed
smikels
Rtek Forum
May 12, 2016 12:34 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
