84-Corroded aluminum wheels (stock)
Old May 17, 2004 | 12:48 PM
The wheels on my 84 are somewhat corroded. Not too bad but in need of cleaning up. There are also some scratches and other marks.
Any ideas on a good wat to make them look new again?
Old May 17, 2004 | 12:50 PM
Sorry about the dual post. I got an error on the first one but it went up anyway
Old May 17, 2004 | 12:57 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
The "plus" wheels are clear-coated. If the clear-coat starts peeling, flaking, etc. then you need to remove the clear-coat and refinish the wheels. The quickest way to strip the wheels is to take them to a commercial stripper and have them tanked. That will also remove the black paint in the center, so that will have to be re-done as well. You can also remove the clear-coat with Eagle 1 "etching mag wheel cleaner" and a stiff brush, but that will take longer and will require multiple applications to get all the old finish off.
Old May 17, 2004 | 01:02 PM
Yea...it looks like a clearcoat. I will have them tanked.
Thanks!
