gslse air intake
Old May 17, 2004 | 01:12 AM
84stock's Avatar
gslse air intake
Has anyone made any worthwhile changes to the air intake on a GSLSE?? Thinking a cone filter, or maybe just a K&N in the stock filter box. Any experience here. (have toyed with my GS for a year, just bought the SE though) Thanks
Old May 17, 2004 | 01:40 AM
JIMMY54's Avatar
GSL-SE PRO
Yup.
-I ported my manifolds.
-I got the HKS adapter and cone air filter
-I did the TB mod reducing intake temps and adding throttle response.
I polished everything but that was just for looks.
Old May 17, 2004 | 02:50 AM
Manntis's Avatar
add to cart
K&N in stock box worked great for me
Old May 17, 2004 | 11:56 AM
j9fd3s's Avatar
Community Builder
me too, i tried an hks filter and a k&n cone and they dont really do anything noticeable
Old May 17, 2004 | 12:07 PM
pimpncuba's Avatar
Replaced the Displacement
i have an spw cone filter on my se and i can notice a considerable difference in throttle response and power.
Old May 17, 2004 | 12:31 PM
84stock's Avatar
My only concerns with the cone filter is what did you do with the afm??? Also, if the factor canister with a K&N works almost as well I think that is preferred for the stock appearance aspect of things. What do you think??
Old May 17, 2004 | 12:35 PM
Mills's Avatar
procrastination engineer
The cone filter attaches to an adapter mounted directly on the AFM. Unless you find a way to seal the cone from hot engine air, you might as well stick with the stock setup.
Old May 17, 2004 | 01:00 PM
MarkPerez's Avatar
Tennis, anyone
The stock setup does draw in fresh air and we all know fresh air is better then under hood air, even with a cone type filter.. if the cone were to be isulated at the radiator support and an enclosier fabb'ed so no warm air from under the hood is drawn in.. i've seen such a setup here before on a 2ed gen. it's not really hard to do either.
rgordon1979
40
Mar 15, 2022 12:04 PM
Frisky Arab
Sep 4, 2015 06:17 PM
