Greddy A/F meter
Old Nov 6, 2001 | 04:54 PM
Greddy A/F meter
Has anyone used the Greddy A/F meter gauge with the autometer a-pillar gauge pod?
I know is 60mm and the pods are meant for 52mm, with some modification can it fit right?
C
Old Nov 6, 2001 | 05:01 PM
BOOSTIN's Avatar
60mm do fit...
I fit a 60mm GReddy Boost gauge in the Auto Meter A-Pillar gauge pods. You just need to sand it out a little thats all, it took me 2 mins to go around the inside of the gauge pod with some sandpaper and it fit like a glove. Hope this helps.
Old Nov 8, 2001 | 05:52 PM
Enought info to let me know that it can be done with just a little sanding. Thanks
C
Old Nov 9, 2001 | 01:35 AM
JaySpec7's Avatar
i just installed 3 60mm GReddy gauges (A/F was one of em).. make sure you sand or use a dremel and cut down towards the pillar... coz the back of the gauge will hit inside... you'll see what I mean..
Old Nov 10, 2001 | 12:06 AM
AnthonyNYC's Avatar
Stay tuned...
How accurate do you guys think the Greddy Air fuel is?
Thanks
Anthony
Old Nov 10, 2001 | 02:11 AM
RX794's Avatar
NYC's Loudest FD
The Greddy A/F ratio guage is VERY accurate, if you want to make sure its really super accurate you may adjust the guage while using a superwideband A/F meter with the adjustment screw on it, just in case you think it isn't reading accurately. But I know this unit as far as guages goes is probably the most accurate A/F ratio guage next to a real superwideband A/F meter.
squirrels
Sep 1, 2024 09:52 AM
edgars95rx7
Link Vi-PEC
Oct 1, 2015 01:59 PM
Rotafuzz
Sep 30, 2015 09:55 AM
