Rear brake kit almost finished
Old May 16, 2004 | 01:58 PM
1RedR1and1RedPEP's Avatar
After 18 months of messing around and waiting for fabrication, my 330mmx28mm rear brake kit is almost done. Brembo 4 piston calipers, and the same rotors used on M2s AP front kit. I will have pictures up very soon. No E Brake is available so dont bother asking. Guys, ths is really cool. I cant wait to test it. Stay tuned for more.
1R1
Old May 19, 2004 | 10:14 PM
Ok, It is official. The good men at A-Spec Tuning will have distribution and production rights to the rear brake kit I have developed. I feel it will compliment Most BIG BRAKE front kits, sorry , no E BRAKE. IT JUST CANT BE. SO DONT ASK. More info will follow soon.
1R1
Old May 19, 2004 | 10:42 PM
rotoboy661's Avatar
nice dude cant wait for pics sorry for peeps in SF (all those steep hills)
any idea on pricing???
thanx
mike
Old May 19, 2004 | 10:54 PM
POM HB's Avatar
Lookie Only
Is the calipers from the Lambo kit...the one that has 8 pots front and 4 pots rear?
Old May 19, 2004 | 11:21 PM
ptrhahn's Avatar
It is hard to believe with all the OEM applications Brembo supplies that someone can't just source a suitably sized rear caliper from an STi, 350Z, or some other high performance car that just has a stinkin' e-brake! I see brembo calipers on a ton of factory cars now.
That said congrats on the near completion of your project!
Old May 20, 2004 | 01:50 AM
BicuspiD's Avatar
Infamous...Butcher...
1R1
Why no E - Brake?
(Someone had to ask)
Most high end rear replacements/upgrades keep the E-Brake function. Is the pricing going to reflect this?
Old May 20, 2004 | 05:16 AM
Speedworks's Avatar
if you're gonna run 330mm on the back, what will you be running on the front then?
Old May 20, 2004 | 08:29 AM
doncojones's Avatar
I believe most of those cars have a drum parking brake integrated into the rotor hat.
Brembo does make an actual parking brake caliper but I'm guessing it's a bit tricky to figure out a mounting scheme for it on the FD upright or else someone would have done it by now.
Old May 20, 2004 | 08:56 AM
Gargamel's Avatar
Having no e-brake sucks. I don't have one anymore on my 3rd gen and I always need to carry something to stick under my tire incase I park on a hill.
Old May 20, 2004 | 09:06 AM
I couldnt make drum type assembly like Doncojones mentioned and there just isnt a way to locate the spot caliper like the other cars that have four piston rear brake kits. It would involve casting a new hub carrier, not something I am interested in doing, but, believe it or not, my fab guy , who is a Can AM car builder from the 60s and 70s suggested for about 20,000 we could do a run of new castings for the hub carrier to make an e brake and a pad to sit the main caliper on. Anyone interested? I sent some photos to A-Spec yesterday, maybe Sean will post them soon. As far as the front goes, 355mmx32 Like what is on the JGTC cars.
Scrapiron7's Avatar
STi Boxer power!
Old May 20, 2004 | 05:31 PM
POM HB's Avatar
Lookie Only
Gargamel,
I've got to ask HOW? If you're already parking the car on a hill, how would you place a brick or anything under tires before car rolling??
Old May 21, 2004 | 09:08 AM
Gargamel's Avatar
Originally posted by POM HB
Gargamel,
Usually keeping the car in 1st gear will keep the car from rolling so I'll just step out and toss a shoe or something under the tire
What IS impossible is when you're trying to work on your car while the motor is running, it has to be on a complete flat surface unless you can ask someone to stick something under the tire.
Old May 21, 2004 | 04:09 PM
POM HB's Avatar
Lookie Only
GotCha!
But, how much load can the 1st gear take? I mean weight wise? If the angle is about 10 degree, it wouldn't be a problem, but how much more can the first gear take?
Old May 22, 2004 | 01:16 AM
MakoDHardie's Avatar
I've seen a lot of Viper big brake kits like Brembo and Stoptech using separate small calipers for the e-brake.
Old May 22, 2004 | 02:23 AM
maxcooper's Avatar
WWFSMD
I don't have a parking brake with my rear brake setup, either. I was somewhat worried about it when I first installed it. Putting the car in gear will keep it from rolling on flat ground or very small grades. I seriously doubt it would hold the car at 10 degrees, which is actually pretty steep. Rotaries just don't hold all that well
However, if you live somewhere reasonably flat, it probably isn't much of a problem. I've never had my car roll anywhere, and I've never had any trouble finding a flat-enough spot to park. I've never had to even drive around to find a flat spot -- it seems most parking spots just happen to be level enough in my area. I have parked on some not-level streets and stuff, and as long as the grade is reasonable, first gear will hold it. I steer the wheel so that it would stop itself on the curb if it did happen to roll, but that hasn't happened yet.
-Max
Old May 22, 2004 | 10:53 AM
doncojones's Avatar
Okay, but there's a reason that type of caliper hasn't been implemented on the FD:
Old Jun 1, 2004 | 09:54 AM
Zero R's Avatar
Just in time to die
Hey giys I will try and get some pics of the rear kit up today I have tried for the past few days but it hasn't let me post so will need to host them on my server for the site. Sorry for the delay.
Old Jun 7, 2004 | 01:27 PM
Sean,
What happened to the pictures, Do you need more photos? I can send some over. Id post them but I have no idea how to do that.
1R1
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
