Vented Hood Update
Old May 15, 2004 | 04:38 PM
Manntis's Avatar
add to cart
Vented Hood Update
We start making the mold on Monday. I've narrowed it down to three designs.
In each there are two main vents, side by side with a thin strip of stock contour in between, running from just behind the rad back to the rear of the hood. The question is should these two vents be smooth, as you see on most Hondas, or should each have tripple vents incorporated in them like on the Feed hood?
In other words, A or C?
Speak now or forever hold your peace
Old May 15, 2004 | 04:45 PM
rotary emotions's Avatar
HEAVY METAL THUNDER
Well, I'm in need of a vented hood, but since I have a FC rad in the car, and that rad is right in the nose (declined), I'd like one custom made to fit my car.
As for your designs, I'd like all of them, it just depends on what style the car is.
Maybe a view from above would help me make up my mind?
Old May 15, 2004 | 04:58 PM
Manntis's Avatar
add to cart
any farther forward and the vents would be out of the negative pressure area anyhow, so air would have to be pushed out by the forward vent. Of course the airstream flowing across it might draw it out as per Bernouli's Principle...
Old May 15, 2004 | 05:26 PM
evil_motors's Avatar
Slide Or Die
i think you are thinking way too much about this.
Old May 15, 2004 | 05:39 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
C
Old May 15, 2004 | 05:49 PM
mar3's Avatar
Administrator
With C, what happens if you're sitting at a light and it starts to downpour? Where does the water pour if the openings go back that far? Will there be alot of people wishing they didn't have direct fire?
Old May 15, 2004 | 05:52 PM
ArrX7ahh's Avatar
A, cleaner, simpler looking. Likely, A is easier to make as well.
Old May 15, 2004 | 05:53 PM
Unsupa's Avatar
Blew my 3rd one 12/8/08
I think A would do it for me.. then again c might get more heat out.. either/or.
Edit: I thought about it and decided A. =D
Old May 15, 2004 | 06:00 PM
Anex 570's Avatar
It Runs!
I'm going for C and same GOOD question as MAR3 asked
Old May 15, 2004 | 06:01 PM
mar3's Avatar
Administrator
Manntis, am I correct in assuming that A, in fact, looks like the 3rdgen hood I posted in the original CF thread?
Old May 15, 2004 | 06:05 PM
Manntis's Avatar
add to cart
You are correct, sir.
C is like the Feed hood.
In both cases if the car is sitting still in the drain it may drip into the engine bay - but it would get no more wet than driving though a puddle - or for that matter rain falling through the stock vent in my '85 Daytona turbo. (When I drive through puddles in my 'tona a rather dramatic plume of steam comes out the stock vent in the hood for a few seconds - making it look like I blew a coolant hose )
Old May 15, 2004 | 06:38 PM
mar3's Avatar
Administrator
You should've made a poll...I vote C, then. I've seen the C hood in person on that 3rdgen and it flat-out kicks a$$....
Old May 15, 2004 | 06:46 PM
tracer's Avatar
A
Old May 15, 2004 | 07:02 PM
RXTbone's Avatar
My 2 cents...
Functional "race" items are nice, but not very practical and are often too bizzare in appearance for most everyday drivers. Why can't someone build a hood with a catchy contour or a set of contours, as opposed to actual vents? There's a very nice hood made for the FD that simply has a concaved area that dips down in the front. I think its sharp. And my guess is that average Joe RX owner would be more interested in such a beast...
Before I get flamed, I know there are hardcore or semi-hardcare drag/SCCA drivers out there, but my guess is *most* drivers don't care about removing heat from the bay, the cars run just fine without doing so. It's simply about looks and having something different than the next guy (which is part of RX ownership anyway, isn't it?)...
And I completely disagree with rain water in the engine bay being no more than what you would get "running through puddle" - there's not that much water that gets into the engine bay. There's a reason that tires have fender wells to work in. Frankly, the thought of rain water splattered all over my engine bay sounds like a bitch to clean up after, and a quick trip to auto rot.
Again, just my 2 cents...
Old May 15, 2004 | 07:55 PM
Anex 570's Avatar
It Runs!
Forget it then, I dont want the hood if thats whats going to happen.
Old May 15, 2004 | 08:00 PM
Manntis's Avatar
add to cart
water on your engine is bad? Hmmm.... my tona has run fine with a stock vent exposing the engine to rain for the past 19 years....
Old May 15, 2004 | 08:16 PM
RXTbone's Avatar
It depends on how much water you're allowing in, and where it's dispersed...
It seems to me, with the design you're proposing, I make one stop when it's raining (and believe it or not, Kansas does have its fair shake of torrential downpours), it looks like you would have water pouring over the battery, A/C, plugs, steering gear, air pump, exhaust manifolds, etc...
And though steam from the engine compartment may look cool - cold water on hot metal is never good.
Don't get me wrong, I love the idea that someone is trying to build products we all might want and I'm not trying to discourage it - I'm simply expressing another, maybe more practical, less radical, and sellable option is available...
Old May 15, 2004 | 08:36 PM
seanrot's Avatar
Always waiting for parts!
Your tooo conservative...
If your that worried about rain make a cheap plexi glass cover. Like the old mustangs used to use to cover the cowl in front of the windshield. If it rains put it in while your putting your sunroof back in (kansas has it share of sunshine too, helps to raise the dead sent of slaughtered cattle, Emporia Kansas weekends stank to all hell). It would also work to keep falling debree out while the car is parked.
Old May 15, 2004 | 08:46 PM
V8kilr's Avatar
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAA
A
B AND C look rice to me
And why not a poll ?
Old May 15, 2004 | 09:59 PM
82transam's Avatar
Never Follow
A definatly, very clean. Did I miss some other thread or something, seems like this is more or an extension of an idea discussed previously.
Old May 15, 2004 | 11:46 PM
Manntis's Avatar
add to cart
You're right about cold water on a hot engine, but really - how much water collects on a hood to drench things in your 'sudden stop' scenario? Have you ever spit on a hot iron? A deluge of cold water on hot metal is one thing. Water droplets, OTOH, dance off the metal as they vaporise.
The battery is off to one side of the engine bay - the vents are well to the centre of the hood, and the centre spine is there not only for structure but to shield the alternator.
As to the steering gear, air pump, etc. these are all sealed components.
Given the number of vehicles on the road with similar or even larger vents in the hood, this whole rain arguement seems much ado about nothing.
Old May 16, 2004 | 12:42 AM
I agree with the puddle people, fenders or not...ever notice when you go through a puddle, water shoots out at about 45 degrees from the contact patch...fender or not, thats going on the engine.
I would vote for A, seems to be the cleanest, least ricey design on the block...and anex...dont just go with what someone elts says...ask around dude...and think about it...go drive through a puddle and see what happens to the top of your hood...
infact, i want someone to drive through a puddle fast, and look under his hood right after and tell us what he sees...put an end to this, i would but my car is in 4 pieces.
Old May 16, 2004 | 12:48 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
C
Old May 16, 2004 | 09:02 AM
mar3's Avatar
Administrator
Whoop....events in the DoO corner unhinged my train of thought, damn those multiple screens! I meant A!! A is the hood I saw in person that was also posted earlier by moi in the other CF thread...
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAA!!
This is the A hood...I apologize but it's from someone else's collection shot that night...
Old May 16, 2004 | 10:23 AM
RXTbone's Avatar
[/B]
If that's the A hood, that's got my vote. I was misunderstanding the concept. I thought you were talking about several vents running the length of the hood... I've seen pics with those types of hoods (maybe CP Racing?)
I'll continue to disagree with the water issue, but I can work around it...
Good luck!
