Why is it so car to find and 18" tire with a 30 side wall?
Old May 15, 2004 | 02:21 PM
c00lduke's Avatar
I looking to find some front tires and i cant find any new/used 225/30-18 through 255/30-18. I'm looking to match the rears and it seems that 335 series tires only come with 30 and not 35 sidewalls? I just dont want to look like an idiot with 35s on from and 30s on the back, maybe if it was the other way around i could deal with it. any suggestions.
Old May 15, 2004 | 08:38 PM
Rx7@Rocketship.com's Avatar
Your notion of aspect ratios is incorrect..
read this
http://www.tirerack.com/tires/tirete...nformation.jsp
Old May 17, 2004 | 01:47 PM
c00lduke's Avatar
so its ratio not a direct size measurment?
Old May 17, 2004 | 02:04 PM
ptrhahn's Avatar
yup.
Old May 17, 2004 | 03:42 PM
maxcooper's Avatar
WWFSMD
height of sidewall = width * aspect ratio/100
(285/30) 285 * 30/100 = 85.5mm = 3.37"
-Max
Old May 17, 2004 | 05:23 PM
'98 Type RS's Avatar
#71
even more simple:
285 (or whatever the width is) x .3 (or whatever the sidewall is). it's a percentage.
Old May 17, 2004 | 08:38 PM
maxcooper's Avatar
WWFSMD
You might be surprised how many people don't know that 30% = .3 = 30/100.
I wanted to be clear, so I spelled it out. But I used .3 when I typed it into the calculator.
-Max
Old May 17, 2004 | 09:03 PM
reza's Avatar
so if you have 245/35/18, it would have the same sidewall thickness.
85.5/35*100 = 244.xxx mm
Old May 17, 2004 | 11:34 PM
c00lduke's Avatar
tire rack suggested 245/40 to match the rear 335/30
Old May 18, 2004 | 01:56 AM
Rx-7Addict's Avatar
Rotary Powered
I HOPE YOU ARE JOKING!!!!
Old May 18, 2004 | 03:34 AM
rynberg's Avatar
Well, their size suggestion is good from a sidewall height matching issue, but necessarily a fitment or handling issue. I would just run 255/35 or 265/35 up front.
I assume you are getting a widebody/fender flares?
Jmolina0163
Oct 3, 2015 10:04 AM
