Dumb Oil Viscosity Question
Old Nov 6, 2001 | 11:28 AM
Question Dumb Oil Viscosity Question
I have an 89 Turbo II.
I need to know what oil to use when I take the car for an oil change.
Old Nov 6, 2001 | 11:39 AM
Ryde _Or_Die's Avatar
There in Canada I would use 10w30 especially since the colder temps are coming. Here in sunny florida I am using 20w50 recommended by someone on here because I am still in the 80s here
Old Nov 6, 2001 | 11:51 AM
does it matter if the oil is synthetic?
Old Nov 6, 2001 | 11:54 AM
Well I have been told that synthetic creates more carbon buildup but I am going to do the ATF trick every once in a while so it won't matter too much. Thats just what I have been told. I know alot of people who use Castrol GTX.
Old Nov 6, 2001 | 01:02 PM
ATF trick?? whats that??
Old Nov 6, 2001 | 01:53 PM
Well in short the "ATF(automatic transmission fluid) trick is a trick that cleans the carbon deposits out of your engine. Do a search by clicking "search" in the top right corner. Also if you go in the lounge they have a topic there with some good info and directions on how to do it.
Old Nov 6, 2001 | 09:03 PM
stiltner@harborside.com's Avatar
WHICH OIL VISCOSITY ????
Synthetic oil is great stuff, but an over kill and too spendy, I`ve put 246,000 Miles on my car with conventional oils { Valvoline and Castrol} What you need in your RX is an oil with a low % of ash, and a low zinc content !!! Zink causes sparkplug fouling !!!
Check out this web site, great stuff !!!!edh@maxey.unr.edu
I`D RECOMEND vALVOLINE TOURBO 10/30 IN YOUR CLIMATE !!!!
HUMMER
alphawolff
Nov 17, 2015 05:57 PM
c0rpse
Aug 25, 2015 11:50 PM
