removing bolts, downpipe install
Old Nov 6, 2001 | 03:16 AM
Michael's Avatar
Help, it's 1:26 am and I'm trying to install a RB downpipe with presilencer, but one of the bolts on cat-y-pipe is hard to get to and not coming off, and the two bolts from the exhaust manifold to the first piping are also not coming off easily, some suggestions please
thanks
Old Nov 6, 2001 | 09:26 AM
Josepi's Avatar
Despise Enmity
Hacksaw.
Soak in a wd-40 type nut buster hehe
Old Nov 6, 2001 | 09:53 AM
Got What You Need!!
I have installed the same exhaust on my car.
THis is what I did: bought some penetrating oil to lube up all bolts. Let it soak for about 5-10 minutes.
The bolts by the cat-y-pipe should come off fairly easily after soaking. If not then re-apply the penetrating oil and wait a little longer. Do this until they come off.
THe header to downpipe bolts are another story. THey don't have hex heads. They are threaded all the way with two nuts holding each one on. These are much more difficult to remove. Using the penetrating oil and a little muscle I finally got them off after an hour. One was bent, one was stripped. The bent bolt was still able to be used (thank goodness) and the stripped bolt was re-threaded using a metric tap and die (the nut needed re-threaded also).
My advice: penetrating oil and patience. You can do it. Just be careful and take your time... I can't stress that enough.
Old Nov 6, 2001 | 09:56 AM
One more thing!!
Dont forget to use anti-sieze compound on the new nuts and bolts with your pipes!
Old Nov 6, 2001 | 11:30 AM
Michael's Avatar
thanks for all the input, I'll try again thursday
Brice_Brice
Aug 18, 2015 10:42 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
