1st gen wheels
Old May 11, 2004 | 06:10 PM
1st gen wheels
What stock wheels from other cars fit on a 1st gen rx?
I have stock 13s right now
Old May 12, 2004 | 03:50 PM
adam c's Avatar
Cheap Bastard
Your bolt pattern is 4 X 110. This pattern is uncommon, and was used almost exclusively by Mazda. If you have the steel wheels, you can get the stock alloys off of an early RX7, or Mazda 626.
I don't think that any other manufacturers use this pattern.
Old May 12, 2004 | 05:54 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
Look at ROH wheels... they make some that fit teh 1st gens...
otherwise.. it's off to ebay you go!
PLook for soem old Wed's or Enkei's as well...
Old May 14, 2004 | 11:27 PM
The Sloth
try Panasport wheels. That's what I had on my 80 rx-7. 195 50 15 i believe.
Old May 17, 2004 | 05:31 PM
i am really lookin for a stock wheels that i can get cheap at a junkyard or something. I was looking for an anwser more along the line of (ex. a 86 to 91 honda civic had the same bolt pattern)
Old May 17, 2004 | 05:45 PM
adam c's Avatar
Cheap Bastard
If you are looking for a cheap stock wheel, there may be plenty of older Mazda steel wheels. I think the early RX2s, 3s, & 4s all used the same pattern as your 1st gen.
Old May 18, 2004 | 09:57 PM
Saru's Avatar
Is wanting another -7
As a 1st gen owner, I can confirm what adam c said. There are no other manufacturers that made alloy wheels in 4x110 and in the correct offset for a 1st gen. The early steel wheels from the 1st RX-7s, and RX-2 to RX-5 (though not RX-5/Cosmo AP) are the same PCD and offset, though they are only 5" wide. Even the stock "+" alloys are 5.5"
If you've got a GSL-SE (or have converted to GSL-SE hubs) then the stud pattern and offset is 4x114.3mm (4x4.5") and the offset is +38/40, I think. Lots of things fit the GSL-SE pattern, try Nissan Silvias, 200/240SX or whatever you guys call them. YMMV.
Old Jun 17, 2004 | 04:15 AM
Mireck 12A's Avatar
Racingbeat dealer
If i'm correct the stock + alloy 5.5 wheels (4x110) have a offset (ET) of 25.
Can anyone confirm that?
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
Marty RE
Aug 13, 2015 11:19 AM
