Today's Hard Core Technical Question Part 1
Old May 11, 2004 | 07:13 AM
Feds's Avatar
More Mazdas than Sense
This one is tougher than #2, but any input would be apreciated.
I put an -se engine into my gsl. I kept all of the FI, and all of the -se sensors. I also put in a 2nd gen rad, and an electric fan. Here's the question:
My temp guage never gets over 1/4, but even then, the engine bay and the rad feel really hot. Is there a difference between the voltage outputs to the temp gauge for a 12a and a fuel injected 13b.
After posting your answer, please move on to question 2.
Old May 11, 2004 | 07:53 AM
Pele's Avatar
Right near Malloy
CarParts.com lists a different sensor for Coolant temp sensor, but the same parts for Engine temp sensor between 12A and 13B 1985 Model year cars.
What year GSL chassis did you use? That'd have a different gauge cluster, so perhaps a different sensor.
The stock gauges are wildly innacurate... Hell I don't even remember them hanving numers on them, only H and C...
I'd get an infrared thermometer and actually check the temps underhood manualy.
Good luck man.
Old May 11, 2004 | 07:55 AM
Feds's Avatar
More info to help Pele. It's a 1985 chassis, and a 1984 engine
Old May 11, 2004 | 09:09 AM
Leigh Adams's Avatar
Struggles with Idling
we've got some smarties on here
Old May 11, 2004 | 11:33 AM
diabolical1's Avatar
i'm not sure i'd go quite THAT far, but they certainly are not the most accurate device on earth. at any rate, considering that fact and also all the changes you've made my advice would be this: get an aftermarket temperature gauge ... better safe than sorry. by doing so you can increase your gauge accuracy and save yourself some worry. protecting the motor is your top priority.
i mean when you said the engine bay and radiator feel really hot, what is your reference?
Old May 11, 2004 | 12:19 PM
Feds's Avatar
My reference is my hand on the rad, and the oil cooler, and the filter. Not the most acuurate, I know, but it seems hotter than most cars.
I am going to try and thermocouple it in the next few days to make sure.
Old May 11, 2004 | 12:26 PM
Jeff20B's Avatar
Lapping = Fapping
Get a compost bin thermometer and poke it down the dipstick hole. It can read the oil's temp right as it's coming out of the rotors.
Old May 11, 2004 | 12:38 PM
j9fd3s's Avatar
Community Builder
um its the same sender unit.
we've noticed that the pre 89 guages are within about a needle width of more "accurate" stuff.
h = 235f/115c
c = 65c
check your guage vs boiling water, its prolly dead on
Old May 11, 2004 | 01:16 PM
Feds's Avatar
Awesome, thanks!
Old May 11, 2004 | 03:43 PM
just remember that skin probably burns before rotor housings warp ...
sorry man, just had to ...
Old May 11, 2004 | 05:58 PM
peejay's Avatar
Old [Sch|F]ool
Re: Today's Hard Core Technical Question Part 1
They're the same sender '81-up.
The "normal" is about 1/4 up on the gauge. Equates to roughly 180-190 degrees.
jase03
Aug 20, 2015 02:09 AM
