I Think I Pop My Motor
Old Nov 5, 2001 | 02:02 PM
ek9220ps's Avatar
Unhappy I Think I Pop My Motor
HOW CAN I TELL IF NO MOTOR IS BAD? I JUSS GOT DONE PUTING MY DOWN PIPE, CLUTCH, FLYWHEEL, TOOK OUT THE AIR PUMP NOW MY CAR DRIVE LIKE ****. IM THINKING ABOUT SELLING MY HKS TI EXHAUST!!
Old Nov 5, 2001 | 03:05 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
Well what are your symptoms?
Old Nov 5, 2001 | 03:14 PM
RecKleSs's Avatar
Adrenaline
Compression test will tell you the health of your engine. Make sure the car is warmed up then have the test done. Also, you can only have the test done at your Mazda Dealership or a rotary shop.
Old Nov 5, 2001 | 03:24 PM
ek9220ps's Avatar
THERE NO POWER, NO VACCUM AT IDLE, HARD TIME STARTING AFTER THE ENGINE IS WARMED
Old Nov 5, 2001 | 06:27 PM
Nike178's Avatar
How many miles on engine?? Are u sure all vacum hoses are in place. Check out the boost sensor hose on the driver's side firewall. With those hose out, u will lose power and idle like ****. Make sure hose is connected to nipple. Good luck...
Old Nov 5, 2001 | 06:39 PM
Pressurized's Avatar
Umm, not too sure, only a compression test will show like RecKleSs said.
One thing though.....when I disconnected my airpump and removed it, my car ran like hell too. My vacuum was at about 12hg/in and the idle was erratic, so I put it back in. Might wanna hook it back up just in case, might as well try, it won't cost anything if it doesn't help.
Old Nov 5, 2001 | 08:01 PM
If it idles like **** (really lumpy) and makes no power....that's a strong sign. Compression test is a must. Don't drive it to the shop. If the apex seal is gone, it may not have wiped out the turbos (though mine sure did - but then I drove it).
Good luck. Good excuse for a ported engine
Old Nov 6, 2001 | 04:37 PM
ek9220ps's Avatar
IF I DO HAVE TO RUBUILT MY MOTOR, WHAT ARE SOME OF THE THINGS I SHOULD DO TO IT? LIKE PORTING, 3MM APEX SEAL?
Old Nov 6, 2001 | 05:19 PM
atihun's Avatar
Hey ek9220ps,
Calm down, and take the caps off first thing.
Next, you need to look over your car, check out your coolant situation, your idle, vacuum, boost, MAP sensor, etc.
There are quite a few things that can make your car run crappy besides a blown engine.
If need some help, I live close in the area and we can meet and take a look.
Let me know.
rgordon1979
40
Mar 15, 2022 12:04 PM
The1Sun
Sep 7, 2015 10:21 PM
doritoloco
Sep 5, 2015 12:41 PM
