Ok some stupid questions on oil and oil pressure
Old Nov 5, 2001 | 10:01 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Ok heres the story, just bought a 88 vert last monday. Drove it and paid close attention to the oil pressure in it.
I always change my own oil, but had a free coupon for the Mazda dealer, I thought what the hell , no one can screw up an oil change.
Well heres how it went, I go in to get it done, and when I leave, I notice my oil pressure is like around 50 or 60 pounds at idle, and like 90 at 3k. After a minute of idleing, it goes back to the normal 20-30 psi. I guess its ok , but it kinda scared me at 90-100 psi at 3k, when it first started after the oil change. I never seen it any higher than 70 psi. Well anyways the ****** put 5W-30 in it, I always used 20W-50 summer, 10W-40 winter or as Mazdatrix recommends in my first generation cars.
So basically my questions are:
1) does weight a viscocity affect oil pressure, and if so how?
2) And what is normally regular oil pressure in one of these?
THANX
Old Nov 5, 2001 | 11:08 AM
HAILERS's Avatar
HAILERS
The fsm at http://www.iluvmyrx7.com Lubrication System, page 2-5 says 3000rpm, 64-78psi. Using a mechanical gauge.
Old Nov 5, 2001 | 02:00 PM
MIKE-P-28's Avatar
So does anyone know in what way oil weight affects oil pressure?
Thanks for the reply on the normal pressures etc...
Old Nov 5, 2001 | 02:50 PM
turboconv's Avatar
Oil weight or viscosity is basically the thickness of the oil. The thicker the oil the more "resistance to flow" the oil has. I would think that the thinner 5w30 they used if anything would cause a lower oil pressure. I base this on the fact that as oil warms up and gets thinner the oil pressure will be less then at a given RPM of when it was cold.
turbo-minivan
69
Feb 4, 2016 12:29 AM
