need help, distributer stuck...cant pass emissions with advanced timing...
Old May 5, 2004 | 03:39 PM
Sk8r_dude's Avatar
Zoom - Zoom...
like the title says, my distributer is stuck, and its had the timing advanced several degrees. it failed emissions because of it, and i cant really adjust it. anyone know how to unstick it? its prolly been this way for 15 years or more...any advice? its my last emissions test...
Old May 5, 2004 | 04:05 PM
Sk8r_dude's Avatar
Zoom - Zoom...
bump
Old May 5, 2004 | 05:03 PM
seanrot's Avatar
Always waiting for parts!
little penetrating oil/WD 40 rubber or brass mallet. give it a tap on the edge of the metal piece with the 10 mm nut holding it in place.
Old May 6, 2004 | 06:45 PM
Sk8r_dude's Avatar
Zoom - Zoom...
already tried that, it would rather bend than move...did the wd40 and heat, and slide hammer....none have worked so far...im getting frustrated...help?
Old May 6, 2004 | 06:50 PM
Rx7carl's Avatar
Airflow is my life
The whole dizzy is stuck? Or just the trailing adjustment?
Old May 6, 2004 | 06:55 PM
Sk8r_dude's Avatar
Zoom - Zoom...
cant move the distributor at all, cant remove it or rotate it!
Old May 6, 2004 | 06:59 PM
Rx7carl's Avatar
Airflow is my life
But you got the bolt/nut loose? Spray with pb blaster or some other penetrating oil inbetween the plate of the dizzy and the aluminum front cover. Let it soak overnight. Sounds like the Al and Fe didnt play well together.
Old May 8, 2004 | 12:39 PM
Sk8r_dude's Avatar
Zoom - Zoom...
damn galvanic corrosion...owell, ill try that...
Old May 8, 2004 | 12:48 PM
85rotarypower's Avatar
love the braaaap
Mine did the same thing. Distributor just won't move without excessive force. I used a standard screwdriver and hammer to move mine. Put the screwdriver in the slot and hammer at it. It will move. Just takes a little time.
RedBaronII
Sep 20, 2015 11:29 AM
JP's 93 fd
Sep 16, 2015 01:12 PM
