Will a bad AFM cause a "limp" condition?
Old May 4, 2004 | 12:35 AM
stacher's Avatar
My 91 vert goes into limp mode. Checking the code I am either getting a code 27 or a code 10 and a code 17.
I checked my OMP and it meets specification and oil is flowing through the lines. TPS meets specifications too and I tried a different ECU.
So.. I am starting to belive that I am reading the code wrong . Code 17 would make scence since I don't have an O2 sensor anymore. Bt I would like to know if the AFM could make the car go into a "limp mode".
Thanks
Old May 4, 2004 | 12:40 AM
Spraintz's Avatar
Edmond Dantes
when my AFM went out it sent many different codes and I think they were the same ones you listed, its worth checkin out. I put a new AFM on and everything was perfect
Queppa
Nov 18, 2024 03:47 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
