Profec B problems....Did i hook it up right?
Old Nov 4, 2001 | 06:27 PM
pp13bnos's Avatar
Pineapple Racer
When i bought my Profec B, the manual it came with new, was pretty much unreadable. So, i thought i figured it out, but i guess wrong. With the PB, turned off, the motor still is making 12+psi on bolth turbos. With it on, and everything turned down all the way, i get 14psi. If i where to have the little vaccum hoses going to the wrong place, would it do this? I did'nt want to swap the places of the hoses going into the stepper(?) motor, and blow up my engine. Or do you guys think i'm getting boost creep?
Heres a list of mods.
M2 intake
Efini y pipe
Pettit ss down pipe
Pettit ss mid pipe
Gutted stock cat back (I like the look of bone stock )
Pettit unlimited ecu
Profec B
Thanks, CJ
Old Nov 4, 2001 | 08:30 PM
evot23's Avatar
Classy
First of all you didn't tell us where you put the hoses so I can't tell you if you installed it wrong.
Sounds like boost creep though.
With the profec off you should normally get about 7psi...with that midpipe of yours seeing 12 isn't uncommon.
Strange...some get the creep and some don't. I know I never did with the SS midpipe.
Old Nov 4, 2001 | 10:38 PM
pp13bnos's Avatar
Pineapple Racer
Sorry about that...I feel like a moron. I just hooked it up, like it says at the Rob Robinette page. I put the "In" side on the stepper motor coming from the turbo and the "out" sode going to the wastegate.
I was under the impression, that a electronic boost controler would help get rid of boost creep. Is'nt it?
Thanks for the help. Tomorow, i'll get some pics. CJ
Old Nov 4, 2001 | 10:58 PM
pp13bnos's Avatar
Pineapple Racer
You know, it should'nt be boost creep. Because it stays pretty steady at 14psi. It does'nt climb any higher than that. So the problem is in either the controler hook up, or something else related to the vaccum lines around the Y pipe.
What i did was install a Y pipe, profec b, and M2 intake all at once. Should of just took my time and did it one thing at a time.
CJ
Old Nov 4, 2001 | 11:20 PM
Bacon's Avatar
IRS 4 Life
did you cap the other side of the wg? theres 2 barbs on it..one needs the out line.and the other needs to have a vac-cap on it...then double check you vac-line to profec
creep can be lessend, but it cant be eliminated completely...creeep is the result of too much exhaust flow and a tiny wg...when i first put my mp on i creeped to 16psi..the i pored the hell outa my wg and could only creep to 10.5-11psi...
Old Nov 4, 2001 | 11:46 PM
pp13bnos's Avatar
Pineapple Racer
I'm not shure what you're talking about, but is it the pre-spool? If thats what you're talking about, i did'nt touch it. Just left the stock hose with pill inside of it.
So, what i should do is cap bolth ends of the pre-spool vaccum hose? Is that correct?
Thanks for your guys help. CJ
Old Nov 5, 2001 | 06:57 AM
evot23's Avatar
Classy
Pay particualar attention to steps 6 and 7. The profec B will not control boost creep. You can only do that by porting the wastegate or getting a popoff valve.
Profec B Install
1.Remove air box or aftermarket intake.
2.Mount the Profec black box or Actuator behind the headlight.
3. Run the wire into the car through the firewall or through the steering column boot.
4 Mount the controller on the drivers side of the car. I chose under the steering wheel were the little A/C vent is that blows into your crotch Just pull out the vent or cut it and velcro the profec under there.
5. Now hook up the power and ground wire. Run the power wire down to the drivers side kick panel. There is a fuse box you can tap into. Just remove one of the fuses and slip the wire in between the fuse and punch it back in.
6. Now its time to hook up the black box. Look down at the turbo and you will notice 2 small hoses that run from the actuator to the wastegates. The outside hose is longer than the other. Remove the smaller of the hoses, which is the inside hose. Run a hose from the Actuator to the IN on the black box and from the OUT on the box to the wastegate.
7. On the back side of the wastegate is a small hose that runs up to the engine. That is what lets the ECU control boost. Pull the hose off the end of the wastegate and cap the nipple on the wastegate. You can let the hose dangle, there is no need to remove it.
8. T-connect the hose from your boost gauge to the back of the profec B.
Put the car back together. Make sure the power works on the profec.
9. Take the car for a spin. Leave the Profec OFF and go WOT. You should see about 7 lbs of boost. Now turn on the Profec with the dials turned all the way down. Which I think is to the left. Get on a good stretch of Highway and in 4th gear go WOT. Slowly turn the dial up to the boost level you would like. Keep the MILD/SHARP dial a few clicks towards SHARP.
There ya have it...apparently there are other variations of install out there. This seems to be the standard one.
Old Nov 5, 2001 | 08:48 AM
pp13bnos's Avatar
Pineapple Racer
Thanks alot Evot23. When i'm up at my shop, i'll tear into it. Thanks, CJ
Old Nov 5, 2001 | 12:42 PM
Bacon's Avatar
IRS 4 Life
naa what im tlkin abt is the wg..
i wish i had a pic... theres 4 nipples down ther 2 on wg, and 2 on precontroll...leave the pre controll alone...now the 2 on the wg (green thingy you hooked *out* line to...theres 2 barbs, one has the *out* line on it and the other needs to be capped...stock it has a hose on it that leads to wg controll solonid...
hope that helped
Old Nov 5, 2001 | 09:28 PM
pp13bnos's Avatar
Pineapple Racer
Is this the correct hose?
I did'nt have much time to work on my car tonight, so i just removed everything, and snapped a couple pictures. Hopefully this weekend i'll have time. CJ
Old Nov 5, 2001 | 09:58 PM
Bacon's Avatar
IRS 4 Life
yep thats the one that should be capped...
then the profec should work
Old Nov 5, 2001 | 09:59 PM
Bacon's Avatar
IRS 4 Life
yep thats the nipple that needs to be capped
then it should work..let us know
err dont know why it double posted, sorry
Old Nov 8, 2001 | 11:33 PM
pp13bnos's Avatar
Pineapple Racer
Thanks guys for your help. As it turns out, everything was hooked up right, just needed to cap the wastgate nipple. The only time i got to test it was on a 40* night. Even when it was that cool, the motor would only see 10psi with the profec off. With it on, but the settings turned all the way down, it would still see 10psi.
I realy appriciate your patience.
Now, to fix the intake leak, and perhaps a tie wrap job.
CJ
Old Nov 1, 2002 | 04:42 PM
coop's Avatar
I have a quick question (I hope)
What is the difference between an actuator wastegate and an external wastegate?
External is an upgrade/ has to be bolted on. Actuator is what the FD has stock?
Old Nov 1, 2002 | 05:02 PM
Dragonz818's Avatar
from what I know an external wategate is 100000 times better at containing boost.
Old Nov 1, 2002 | 05:04 PM
coop's Avatar
so the stock Wg on an FD is an actuator type?
Old Nov 1, 2002 | 05:53 PM
Toadman's Avatar
Nomad Mod
Yes, so set the dip-switches on the unit accordingly. (They come factory-preset the right way). Here is a site where you can download the factory manual, in english even.
Old Nov 1, 2002 | 05:57 PM
coop's Avatar
And you use the 'over boosting' setting when you get more than 7psi with the settings set to 'low'...
I am still getting about 9 psi with it set all the way low..
any thoughts...
I have the hoses hooked up right, and the other side of the Wg blocked off...
Old Nov 1, 2002 | 08:20 PM
pp13bnos's Avatar
Pineapple Racer
I had the same problem too, until I went non-seq. Then I would see 7psi with creep to 9psi. CJ
Old Nov 3, 2002 | 07:29 PM
PsToNs SuK's Avatar
can someone post a link to that website where it tells you how to hook up the profec b. I got the same problem just a little more drastic. Also when u hit 15psi or higher will the comp shut stuff down?
Old Nov 3, 2002 | 08:38 PM
coop's Avatar
Here are some of the websites I looked at
http://www.scuderiaciriani.com/rx7/profec_install.html
and
http://www.rx7turboturbo.com/robrobi...boost_note.htm
but I don't think my problems are from the profec B...I think there is something else I am not aware of.
Is there a certain hose (or couple hoses) that are used for first great boost??? maybe one of those has a leak or something...I just can't figure out why I get practically no boost in 1st great...hummm...
24seven_dada
20
Nov 10, 2018 12:03 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
MidnightOwl
Sep 25, 2015 10:24 PM
