Damage report *NO 56K...*
Old Apr 30, 2004 | 07:16 PM
Lawerence's Avatar
Well after the accident last night, i washed and waxed my car to see all the damage
There is one cip in the paint. But I am worried about the wheel alignment like I was saying.
Here is the passanger side front wheel, which seems normal:
Notice how the wheels is centered.
now here is the drivers side:
Three things to mention here:
1. The wheel is pushed back towards the fender (it is not bent)
2. The car is sitting lower on this side. (im thinking blown shock?)
3.The grass in between the rim and tire. Is this bad? (well i know its not good ) But how bad is it?
In this pic, you can see how the drivers side is sitting lower than the passanger side.
Again, i think that is the shock.
I want to stress that the car drives fine. I did notice today that it pulls left very slightly. But that is the only thing I notice while driving it.
Im bringing in my car to my mechanic (mike lowe) on monday. BUt I want to know what I should be expecting.
Old Apr 30, 2004 | 08:01 PM
1SxyRXy's Avatar
my fc broke
well first off ditch the nozzle lights and then go under the car and see if there is any damage done and then find that tiburon and kick that guys ***
Old Apr 30, 2004 | 08:03 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
get rid of the stupid LED ****. And then look under the car probably the A arm or the steering linkages.
Old Apr 30, 2004 | 08:32 PM
Nick86's Avatar
Yup, still here
I'm not sure if I'd consider this "Normal"!
Seriously though - you probably have damaged more than just the shock. Even if you remove the shock, the wheel wont be pushed back at all. The ride height could be shock related, but the wheel position is something more serious.
You'll have to get the car up on jackstands and take the wheel off to see what's going on.
Old Apr 30, 2004 | 09:02 PM
BlackRx7's Avatar
Daily Domestic Killer
I've busted up an alloy rim way worse than that (not proud of it) it turn out I hit the curb so hard that it bent the spindle of the wheel, as well as the frame of the car....it drove fine after it was all fixed and frame straightened but it still , pulled very slighty
Old Apr 30, 2004 | 10:19 PM
Sponge Bob Square Pants's Avatar
I'd guess it's a bent A-arm.
Like they said though, just jack it up and take off both front wheels. Compare them and look for damaged/bent parts.
Old May 1, 2004 | 12:57 AM
PilotSi's Avatar
I had the exact same problem on my Honda Prelude - it turned out to be a bent lower control arm and a bent subframe. The lower control arm was easy to fix - and for the longest time, I thought the actual frame was bent. Finally went to a REALLY good shop (3rd shop I visited) and they noticed a VERY slight bend in the subframe. I went to the junkyard, replaced the subframe and voila! Fixed.
Even though it drove straight before the fix, it would understeer HORRIBLY at low-speeds (the car would shake at say 25mph right hand turns) but it would turn on the left hand side just fine...I autox'ed like this too, it sucked royal ***.
David
Old May 1, 2004 | 06:30 AM
totallimmortal's Avatar
Is that thing Turbo?
hmmm just noticed that my fac's front wheels are just like that cept min sits level, maybe the reason for my high speed shake in the steering wheel?
Old May 1, 2004 | 09:22 AM
Lawerence's Avatar
Im going to put it on a lift and check it out.
Oh and the nozzle lights came with the car... They are coming off
Old May 1, 2004 | 10:56 AM
greenchili's Avatar
Man that really sucks....glad you're OK.
Did they/you find the tiburon jerk?
Old May 3, 2004 | 09:36 AM
Lawerence's Avatar
****UPDATED****
Took it in to the shop this morning and just got a call back.
It looks like the ball joint is dead, and the strut. Total in parts is $162.56.
Im not sure on the cost of labor yet.
But I am so relieved that is is such a cheap fix. In one of my older cars (02' SpecV) I got in the same type of accident, at the same speed. But the car broke both axles and cost over 3500 to repair.
Thank goodness the RX7 is stronger. I think my love for this car just multiplied by 10x.
Old May 4, 2004 | 04:57 PM
so how ya liking them fm901s???
i got a set a while ago .. and I was curious how you were taking to them
musker
Oct 1, 2015 05:58 PM
