Is the Engine Damaged?
Old Apr 30, 2004 | 07:05 PM
TheDude's Avatar
Exclamation Is the Engine Damaged?
Just earlier today I rear-ended a person ( not smooth, I know) on a busy street. Other than some bent headlight covers and pushed in bumper, i thought the car was fine.No leaks and it drove just as smooth as always with no funny feelings all the way up the RPMs. Well anyway waiting at a light on the way home I notice something very strange with the idel. It was as smooth as always but about every 5 seconds it drops about 100 RPMs and the car vibrates a little. This happens for like a second and then it recovers. Then in 5 seconds it happens again. I checked the engine bay and i dont notice anything obviously wrong but im no mechanic. If you have an idea of what might be happening or have had this problem please help me.
Thanks- Josh
Old Apr 30, 2004 | 08:39 PM
DAN CARWIN's Avatar
You probaly broke your blinker fluid resivor!!!!!!!!!
Old Apr 30, 2004 | 09:10 PM
vaughnc's Avatar
knowledge junkie
Old joke. Seriously make sure the relays in front nose are still connected and no wiring is stripped.
If the accident just pushed your nose nose & headlight covers in you probably havne't damaged the primary frame, just the body and nose subframes which can be bent / beaten back into shape.
Old Apr 30, 2004 | 10:29 PM
mcnannay's Avatar
Lean Mean Speed Thingie
do you a/c? It kinda sounds like your compressor engages and kicks down the rpms a bit, the rpms are supposed to compensate for that but like vaughnc said, you could have broken a relay or solenoid that controls that...
i dunno just an idea
Old May 6, 2004 | 01:08 AM
TheDude's Avatar
Thanks for the replies. Turns out I needed a new battery. I baught one and the problem is gone. Now im trying to bend everything back into shape. Fun.
Old May 6, 2004 | 01:30 AM
Madrx7racer's Avatar
and you were worried about all this other ****......hahahah
astrum
24
Nov 15, 2017 08:44 AM
